Question about LG RH177 DVD Recorder/HDD Recorder
LGRH177 I have had this over a year with no problems...now will not output a picture ('no signal' on tv) and keeps displaying 'please wait' message over and over. Can anyone tell me a possible fix or way to reset the player...THANKS
  • Anonymous Dec 02, 2007
    I have the same problem. What should I do?
    My email adress is lovassz@freemail.hu
  • 3 Answers
It should be the internal HDD failure...befause the player fails to checking the HDD during starting up ...
good luck !
Posted on Dec 19, 2007
Hi, We have a Panasonic Viera Plasma TV. The TV was on when all of a sudden we heard a few clicking noises and then the picture was lost and a 'no signal' message was displayed. We tried other channels...
It sounds like you have taken the steps to isolate the problem to the TV. it seems to be a bad tuner on the Main board. The no signal displayed indicates the TV is otherwise okay. If you have a DVD player or other source you can connect, and you get a picture, then your TV has a bad tuner for sure.
Feb 21, 2015 | Panasonic Televison & Video
Only half the screen displays on DVD player, Wharfedale WDP 1210
Is your DVD Player's model WDP1210 or WDP3397B.
If you are using one of these model I will strongly recommend to use AV output to a TV instead of using its LCD screen. If you get full picture at TV, You will isolate the matter that LCD module has problem. If so you can check with a local repair center. If you have any help regarding TV connection via external AV cable please post a follow up message
Hope it will help
Happy New Year
Jan 01, 2008 | Televison & Video
Dynex L26 10A purchased little less than year ago has audio, but black screen. When first turned on screen will display: "Please Wait", then screen goes black, but audio can be heard. Tried uplugging from...
Call for warrenty serviced,u still have warrenty inforced until a year.Ur tv have intermittently signal shutdown before it come throught the Tuner board not,carrying to the LCD Screen to produced a picture.
Jul 03, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Black & White picture for DVD
When using the Component outputs on the player, make sure they are enabled in the player menu system (or sometimes there is a rear panel switch and sometimes both), as most players default the Component outputs to off. Even when the Component outputs are off, you will often get a color-distorted signal out as many players share circuitry between the various outputs.
May 19, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
Try all of your HDMI inputs, one may be rated at the correct voltage to be able to display the video. The offical part that Panasonic was giving for this was PDPHDMIKIT, its basically a HDMI extender that regulates the voltage. The part is still available online, try partstore.com or andrews-electronics.
Apr 23, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Incompatible signal
Check your resolution settings on you playstation 3 menu's. If you are using an HDMI cable, there is a chance that your ps3 could be trying to output at 1080i or 1080p. The unit you have only goes up to 720p and if you set it any higher than that, you run the risk of having picture issues, or not getting a picture at all. Good luck to you
Mar 28, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Signal is not compatible with this input when i connect my laptop
If the screen resolution on your laptop is to high or not supported by the TV, that is the usual error message.  I'm not sure what video output you are using but if it's the common S-video output, high resolutions will not be supported through it so maybe try a lower resolution and work your way up until you get the message again.  Then you will know the threshold.
Mar 26, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV displays a "no signal message"
is there any picture at all ? if no signal message regardless of any signal input , ur ad board need to be change.
Sep 19, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Feb 10, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
No video signal
• The resolutions available for HDMI output depend on the connected TV or projector. For
details, see the user’s manual of your TV or projector.
• When the resolution is changed during playback, it may take a few seconds for a normal
image to appear.
• If you set the HDMI output resolution 720p or 1080i, HDMI output provides better picture
quality.
• If 720P or 1080i is selected, C-VIDEO, S-VIDEO and component video will not ouput video
signal. Press and hold the SUBWOOFER button on the front panel to reset the HDMI
Resolution setting.
Oct 06, 2007 | RCA RTD258 System
LG RH177 DVD Recorder/HDD Recorder Logo
625 people viewed this question
Steve Allison
Steve Allison
