Tomtom GO 510 Car GPS Receiver Logo
Posted on Mar 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't operate when using it with car adapter
My Mio works fine with the built in battery but when I use the car charger it dispalys a chrging icon, or a sync Icon. Do I need a car battery adapter instead of a car battery charger id there is a difference.
Thank you
Michael Thomas
Level 3:
  • Master 3,056 Answers
  • Posted on Mar 27, 2009
Michael Thomas
Master
Level 3:
Answers
3056
Questions
52
Helped
1307449
Points
10935
Hi there
i would refer to your users manual and make sure that you are not using something that is not compatable with your system so you dont damage the unit
Screen only lights up on battery power but no ac adapter/charger tried three ac chargers all do the same thing so its not screen or charger
Hi David
It sounds like a fault to its power transition section circuit. Actually, this circuit is built inside the mother board to your laptop.
Please contact the authorized service center, and describe and show them the problem you do experience now, with your laptop. It can be rectified. Gopakumar Gopalan Google
My mio 320 is stuck on transfer mode when connected to charger it thinks its connected to computer
I've had a lot of issues w/ the operation of my MIO C320, including this problem ... but ONLY whenever I tried using any other mini-USB cords (like from my phone or Garmin GPS chargers), with my MIO C320. There's something unique about the mini-USB pin-out configuration MIO uses that allows you to either charge or update their units (using the transfer function), using MIO's supplied mini-USB cables. (I've labeled my MIO cord as "MIO GPS", on a piece of masking tape wrapped around the cord.) I'm trying to recall whether the MIO's cords worked properly w/ all of my other devices, and I can't think of any that did NOT function properly. So, maybe you could experiment and - if that's the case w/ your devices also - avoid further issues by keeping JUST the MIO's charger in your vehicle?. Sorry this is so late, but I hope it helps! Cheers, The Foxxx
Jan 08, 2014 • Mio GPS
I have mio s600 and during the travel the car charger has stopped working, so the navigation automatically started to use it's one battery. After I pulled out the charger, and sticked it in again,
If you are using the lighter plug for charging it may have a fuse inside the plug itself the plugs into the lighter socket,,,,,look for a fuse there or if have a volt meter check for voltage reaching the unit when plugged that way If voltage is good to the unit from the car source the battery may be bad, either not getting a voltage for charging or battery not holding a charge.
Dec 07, 2012 • GPS
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
When i use the computer with full charged(batter) w/o the charger inserted it is working fine once the battery is low, i insert in the charger it will hand my compuer. Basically now my laptop cannot be...
Hello.
From your description, your A/C adapter (power charger) is faulty and needs to be replaced. Look online or at a local shop for a replacement. Targus manufactures a good A/C adapter. Check to see what adapter works with your laptop.
Hope this helps.
7helpful
2answers
Navman wont charge in car while operating
check the end of the charger unit and unscrew the end to replace the fuse.
Please rate our help to keep the FREE service online ++++ Thanks for using FIXYA
BATTERY NOT CHRGING
Three reasons. 1. The charger is bad. 2. The Battery is dead. 3. The charging circuit is faulty. To check each Use a different charger or use a different battery. If both are fine then the third fault is confirmed.
Mio 168 not charging when using Car Charger
You have to have an ignition switch on, only then to connect a device. It is to protect device against an electric shock.
firo
Dell Inspiron 2200 has been working fine, But now won't turn on.
1. Try and check the voltage output of your adapter using any ordinary voltmeter. It should have a voltage reading close to the dc rating printed at the back of your laptop.
2. Even if you have problem with battery, the laptop should power on. Otherwise, if both battery and charger is working fine, then there is a problem with the charging circuit that is built-in on the laptop's mainboard.
If charger is defective, then its more practical to buy a new one instead of sending it or repair. Repaired chargers can cause more problem for you in the future.
Mio fails to charge and doesn't work
it may be a battery problem, USB charger problem or something. Why not call them and ask? They are nice (you can tell them I told you so). Look up the number at
http://www.mio-tech.be/EN/support/support-overview.php
Hope it works
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
