Question about Mitsubishi VS-5043 50" Rear Projection Television
VS - 5043
Yesterday,, it turned off for no reason. Came back on okay. Today, we turn it on, green button lights for a sec,(no picture) then turns off?? Please advise. Thanks
    Genius:
  • 1,153 Answers
1. SHORT DETECT SHUT DOWN (PIN 15 OF IC700) CHECK FOR OPEN L902 PART # 351P070010 OFF Q904 C (15 V SUPPLY) ON THE MAIN PCB. 2. SHORT DETECT SHUTDOWN (PIN 15 OF IC700) CHECK FOR SHORTED D913 PART # 264P722010 AND OPEN Z901 PART # 283P039020 (Z905 AND Z900 MAY ALSO BE OPEN BECAUSE OF THIS). 3. X-RAY SHUTDOWN (PIN 55 OF IC700) CHECK FOR A LEAKY D5A09 PART # 264P244030 OFF PIN 6 OF IC5A01. 4. X-RAY SHUTDOWN (PIN 55 OF IC700) CHECK FOR LEAKY D5A21, PART # 264P045040, IN THE BEAM PROTECTION CIRCUIT ON THE MAIN PCB. 5. CHECK FOR LEAKY Q5A03 AND/OR Q5A04 BOTH PART # 260P559050, IN THE HIGH VOLTAGE DETECT CIRCUIT, ON THE MAIN PCB.
Posted on Aug 26, 2007
SOURCE:
Video
What kind of input are you using
Nov 05, 2017 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs 5043 no picture
have the tubes checked out you may have a loose connection
Jul 15, 2008 | Mitsubishi VS-5043 50" Rear Projection...
My TV won't turn on...
check the power supply sounds like its going out
Jul 08, 2008 | Mitsubishi VS-5043 50" Rear Projection...
TV turns on, but no picture or sound from any source
You need to have the Liquid chaged in the Projection tubes & /or Rear lamp replaced
Jun 24, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
50" Mitsubishi
Check the 5 volt pico fuses on the center board. F9A05 is most likley open. This would indicate bad convergence amps. The two Convergence amps and fuse should be replaced.
Josh
Mar 02, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi vs-5051
First you can safely take off back and look for Screen controls&Focus, Gently turn up the 3 screen controls this will add light to picture, but you need to evenly turn up, the 3 colors are red, blue, green. the other 3 knobs are for focus. Do not turn them if you do you will need to realign the focus also. And if this doesn't help then there is a high voltage capacitor leaky in the flyback area.
Sep 14, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
