Question about Garmin StreetPilot 2620 GPS Receiver
Garmin Streetpilot 2620 Goes not go to maps
For some reason whenever I turn the unit on the main screen that says streetpilot comes on then the saftey warning not to use it while driving then when you click ok it goes back to streetpilot 2620 and keeps making the same circle. Is there any way to reset the unit. I know by holding down certain buttons while turning the unit on you get different screens is there any way of making it read and display maps again
  • 2 more comments
  • Anonymous Nov 11, 2007
    same problem, any help?
  • Anonymous Feb 19, 2008
    I have a same problem, and I think I can fix it, may be not. Any how, I
    bought a cornice drive on eBay and as soon I will get it. I will load
    my maps on to it with usb connector after that I take it a part and
    remove it from its case. Then I will take my Garmin Streetpilot 2620
    apart remove the old cornice drive and install the new drive. I suspect
    it will work like a charm. To check your GPS at boot push and hold
    "menu-find" buttons simultaneously and you will get a screen to verify
    your problematic cornice drive.
  • pradstah Aug 18, 2008
    i have the same problem. did you resolve yours? if so can you please post.
  • terrykim Dec 11, 2008
I did update to the 4.8, and worked for about 10 minutes, and then went back to the old routine of booting over and over, and will not except map. I think I might sent it back to garmin in a few days after I get to tired with it.
Posted on Feb 12, 2008
Http://www.geocities.com/diverhank/SP26X0UndocumentedFeatures.pdf Here are the links for the manual with a master reset & version 4.80 update.
Posted on Aug 30, 2007
I would like to know the same thing! My father has the same unit and he updated his with version 4.80 & web updater (both free) on garmin and it solved his problem. I believe my problem is that my North America v8 did not install properly. ????? well see
6ya staff
SOURCE:
Won't Turn on, not even when connected to mains - LED lights on but no HDD drive light
The HDD can go at anytime without warning, does the Asus logo come up on the screen?
Apr 08, 2012 | ASUS Eee PC 1000HE Netbook
Start-up loop
Hold down PAGE, MENU, and FIND then turn unit on to perform a Master Reset. That might do the trick. There are some other undocumented features you might be interested in available here: http://home.socal.rr.com/diverhank/SP26X0UndocumentedFeatures.htm#_Toc144991134 That site also has links to manuals, if you need them.
Aug 28, 2007 | Garmin StreetPilot 2620 GPS Receiver
Gaarmin 2620
Hi hummer49....Your GPS Software needs to be updated by clicking on the following URL: http://www8.garmin.com/products/webupdater/howtoinstall.jsp If you have misplaced your Owner's Manual, you may download a copy by clicking on the following URL: http://www8.garmin.com/manuals/439_OwnersManual.pdf Please update your post if you need further assistance and also to update me on your progress....good luck my friend
Aug 06, 2007 | Garmin StreetPilot 2620 GPS Receiver
Top row of number and letters not responding when I punch them in. for example #1 comes up #4, #2 comes up #5,and #3 comes up #6! How do I resolve?
To calibrate your Streetpilot c-Series touch screen, follow these steps:
    1. Begin with the unit turned OFF and unplugged from a power source.
    2. Power the unit ON, continue to hold the Power button for 1 minute.
    3. A screen will display instructing you to Press dot in the lower left corner.
    4. Release the Power button and touch the sequence of dots until your unit displays, Calibration complete.
    5. Your unit should now function normally.
I hope this helps. Please rate my reply. Thank you.
Jun 27, 2011 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
Will not let me change locations while moving how do i turn off that fuction?
This is a safety feature that comes turned on by default. While you are driving, you cannot enter new directions/information as it is unsafe to do so. The unit normally asks you if you want to override this at the time, but you can also turn it off while stopped by pressing the icon at the bottom of the screen that looks like a wrench. Then press "System" at the top middle of the unit. Where it says "Safe Mode" press the "On" key. At the next screen, press "Off." The unit will now allow you to enter information while it is in motion.
Sep 26, 2009 | Garmin StreetPilot c550 GPS Receiver
Street pilot 510 can't get rid of saftey mode ex-rental
Safety mode (prevents you from changing routes whilst in motion) is enabled disabled in the system options.
Found by navigating Setup (spanner at bottom of main screen) --> System --> Safe mode
Mar 01, 2009 | Garmin StreetPilot c510 Deluxe GPS...
Garmin 320 shuts down
I suggest you take it to the store. Probably an internal errorr
Mar 02, 2008 | Garmin StreetPilot C320 (010-00401-00) GPS...
Most likely your hard drive is gone bad. Push "menu+find" buttons then turn on, you will get diagnostic screen, it will show if your cornice drive is bad. It will say"Cornice Dive removed"4f3efc6.jpg
Sep 23, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin streetpilot 2620
Hold down Menu-Find buttons if you get this screen, your hard drive gone bad. Garmin charges $275 to replace your unit8863097.jpg
Aug 16, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin StreetPilot 2620 GPS Receiver Logo
534 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
