Question about Samsung DouCam VP-D5000i Mini DV Digital Camcorder
My camera shows a blue screen when I record
I have a Digital Video Camcorder D5000iMini DV. It functions properly on play back but when i press the record button, it displays a dark blue screen with blurred images in negetive.Initially I tried to Switch it off then on again , It used to work but now it does not record. Please let me know what is the cause and what is to be replaced or repaired. I do not trust local vendors, who prefer to make money and might damage it.
  • 1 more comment
  • cardos Feb 12, 2008
    I have a Digital Video Camcorder D5000iMini DV. It functions properly on play back but when i press the record button, it displays a dark screen.Initially I tried to Switch it off then on again , It used to work but now it does not record. Please let me know what can i do to fix the problem.
  • Anonymous Feb 27, 2008
    J'ai exactement le même probléme depuis le mois d'août 2007. J'ai pas encore trouvé de solutions. De même je pense qu'en absence d'un service technique de Samsung, donner l'appareil à un bricoleur du coin n'est qu'une aventure.
  • sonu999 May 11, 2010
    have a Digital Video Camcorder D5000iMini DV. It functions properly on play back but when i press the record button, it displays a dark blue screen with blurred images in negetive.Initially I tried to Switch it off then on again , It used to work but now it does not record.... Read more
    Champion:
  • 206 Answers
CCD sensor is faulty. Must be replaced and your agent should do this free of charge. If you have to pay for this repair then expect to pay +- 30% of the price of a new camera . But the repair is very effective and you should get couple of years out of your camera afterwards.
Posted on Aug 27, 2007
Put it in the bin.
Posted on Jan 28, 2008
6ya staff
SOURCE:
I get a flashing red warning symbol during play and record. It is on the bottom LHS of the screen just above the 'camera shake' indicator and looks like an oval with a back slash through it. This symbol is...
i think it's the button cell that's CR1616 that's hidden when your battery is in the camcorder. Remove the battery to reveal that little plate to replace your button cell. It functions properly just that time and date might not be recorded.
Jan 02, 2011 | Canon MV940 Mini DV Digital Camcorder
No playback after recording
check if you are using with a full battery..
if yes reset the unit and try again..
To reset the Camcorder, remove the battery from the Camcorder, press the Power button for 30 seconds and then reinsert the battery in the Camcder.
Dec 12, 2007 | Sony DCR-VX2000 Mini DV Digital Camcorder
During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Apr 18, 2009 | Canon ZR40 Mini DV Digital Camcorder
Camcoder (Panasonic PV-GS15) does not play back recording
Sorry to say- but it is trashed.. It would cost more to fix it than it would be to buy a new one.
May 06, 2017 | Panasonic NV-GS10 Mini DV Digital...
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
panel.
• AV2: Audio/Video Input mounted on front
panel.
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
My trv-19 cannot record video
If you can play back ok but cannot record then your CCD sensor is faulty: replace CCD block.
Sep 05, 2007 | Sony Handycam DCR-TRV19 Mini DV Digital...
My GR-AXM18 JVC Compact VHS w/LCD Screen isn't recording!!
Blue means that there is no signal. It can be that the head is dirty. Use a cleaning casette, (do not use cotton swab and alcohol)
May 25, 2007 | JVC GR-D250 Mini DV Digital Camcorder
IN CARD POSITION
A properly functioning camcorder will report this if it has both a card for recording and a tape mechanism for recording, with a switch set "in card position" when you press the movie mode record button. If you have a camcorder like this, look for a button marked "photo" that is used specifically for snapping still photos.
May 18, 2007 | Canon MV530i Mini DV Digital Camcorder
No sound when playing back video
I had the same problem. Try this: open the LCD screen so that you can access the playback buttons.Make sure camera is in playback mode. Press the "menu" button. Select "narration" . Switch narration to "off" .Now you should hear the recorded audio when your tape is playing.
Jan 03, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Recording sound on video.
Audio Dubbing may vary by model. Most Digital Camcorders are equipped with this feature. To verify that your model is, please view the User Manual. Audio Dubbing * The AUDIO DUBBING function only works in PLAYER Mode. * You can add sound to the original sound on a pre-recorded tape, recorded in SP mode with 12bit sound. * Use the internal and external microphones or other audio equipment. * The original sound will not be erased. Dubbing sound 1. Set the camcorder to PLAYER mode. * If you want to use an external microphone, connect the microphone to the external MIC input jack on the camcorder. * When you wish to dub using the External A/V input, connect the AUDIO/VIDEO cable to the camcorder by inserting the cable jack into the A/V in/out terminal at the left side of the camcorder. - Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. - Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. 2. Press the (PLAY/STILL) button and find the timeframe of the scene to be dubbed. 3. Press the (PLAY/STILL) button to pause the scene. 4. Press the A.DUB button on the Remote Control. * A.DUB will be displayed on the LCD. * The camcorder is in a ready-to-dub state for dubbing. 5. Press the (PLAY/STILL) button to start dubbing. * Press the (STOP) button to stop the dubbing. Notes: * You can not use the audio dubbing function while playing a write protected video tape. * When you wish to dub using the External A/V input, you must connect the AUDIO/VIDEO cable to the audio system from which you wish to record. * You cannot dub sound on a pre-recorded tape in LP or 16 bit mode. Dubbed audio Playback 1. Insert the dubbed tape and press MENU button. 2. Turn the MENU DIAL to highlight A/V. 3. Press the ENTER button to enter the sub-menu. 4. Use the MENU DIAL to select AUDIO SELECT from the submenu. 5. Press the ENTER button to enter the sub-menu. 6. Using the MENU DIAL, select the AUDIO playback channel. Press the ENTER button to confirm the audio playback channel. * SOUND1 : play the original sound. * SOUND2 : play the dubbed sound. * MIX(1+2) : play back SOUND1 and 2 equally mixed. 7. To exit, press the MENU button. 8. Press the (PLAY/STILL) button to playback the dubbed tape. Note: When you playback added sound (SOUND2 or MIX mode), you may experience loss of sound quality.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung DouCam VP-D5000i Mini DV Digital Camcorder Logo
153 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
