Question about i-rocks IR-4100 4-Port USB Hub
Not Reading Peripherals - i-rocks IR-4100 4-Port USB Hub
When I plug in my external drive and my clip drive into the i-rocks USB hub, the hub doesn't read / see them. When I plug the peripherals into the computer tower itself, they show up. This is the second time I've had this problem. The first time, I just bought a new hub, and have used this current one for several years. However, it seems that i-rocks hubs simply give up after a few years. I'd like a recommendation on a higher quality brand than i-rocks.
  • anewist Aug 27, 2007
    Valiis, Thank you for your response. I will look at Belkin.
    What I have also learned is that a self-powered hub would work better. A hub that you plug into a power source. Mine is bus-powered, plugged into my computer. I specifically bought a bus-powered hub because of a lack of sockets for all of my peripherals. However, I will go with self-powered for now.
    Thank you for taking the time to write in. I appreciate it.
    Scholar:
  • 72 Answers
If your looking for a good quality USB hub, i would go with a Belkin. They do cost more than most other hubs, but from the 8 years i have been at my retail store, they have had the lowest return rate of all that I have sold.
Posted on Aug 27, 2007
I look for the driver for I-Rocks IR-4650 3+1 ports USB 2.0
Hi
The I-Rocks hub is a USB hub and needs no drivers for Windows XP or later, as they are included in Windows and loaded as necessary when the hub is plugged into the computer.
If you are having problems, I suggest you go here:
http://www.manualshelf.com/download/i-rocks/ir-4650/0AlBUfl5HfUV--3rO8rt4zmuK8o/technology-rapid-usb-31-port-hub-quick-installation-guide.pdf
and save the full manual to your computer. There is a troubleshooting section in particular which may help you.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 25, 2014 | i-rocks Computers & Internet
My book doesn't have power
Did you plug it in?
USB Powered Devices:
If you're using USB for power then you either need a powered USB hub or the device must connect directly to the computer's USB port bypassing the hub.
If the USB hub doesn't plug in to the wall socket then it is not a powered hub. Basic USB hubs do not supply power to devices or charge an external device like a cell phone. The hub must be of the powered variety and plug into the wall before you can use it for things like this.
TIP:
Get two USB hubs, one powered and one not. If you're using a USB hub for anything other than connecting a flash drive or your wireless keyboard and mouse receiver, get a powered one. Doing so allows you to charge multiple devices through USB and it will provide power to other peripherals like a laptop cooling pad, external hard drives, etc.
Sep 29, 2012 | Western Digital My Book Essential 1TB...
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
Some of my peripherals, trackball inc. want to be connected to the netbook instead of settling for my hub. What do I HAVE to connect to the computer among CD drive, hard drive, printer, keyboard,...
Most likely your USB hub is not capable of supplying enough power to support all your peripheral devices. USB devices are powered by 5 volts from the USB port. If you connect a hub to a USB port and connect a lot of devices to the hub, there is not enough 5 volt power to let all devices work. To fix this, most USB hubs have an external power option that when plugged in will supply extra power for any connected devices.
If your hub does not have an external power option I would suggest you purchase a new hub that does have an external power supply.
Good luck :)
Jan 25, 2011 | ASUS Eee 4G Notebook
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Sep 21, 2009 | Targus PAUH217U 4-Port USB Hub
I connected the external floppy drive to a USB hub which in turn is connected directly to a USB port on my Dell desktop which runs Windows XP Home Edition 64 bit version and the drive just runs and will...
Yes, the external floppy drive must be connected directly to a USB port on the computer instead of to a USB hub.The PC can't see the drive thru the USB hub. Applies to both 32 and 64 bit.
Sep 07, 2009 | Computers & Internet
My irocks enclosure only came with 98 drivers where can i get xp
Xp does not need them but check the information below before you panic.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 30, 2009 | i-rocks External Hard Drive Enclosure -...
My computor switches off the moment i plug in the wd passport.
Probably a power issue. Your new computer has less extra power capacity and the external drive is pulling from the USB port power.
What you need is a USB hub with an AC adapter that powers the hub and any devices that are connected to it from the external AC power adapter and NOT from the USB bus. In other words look for an external power adapter that plugs into the wall as well as into the USB port. Don't get a recharger for an iPOD as that will not do you any good. And don't get a hub that says "powered" or "external power" that does not have an AC power adapter because it is still sucking power off of the USB port.
Try shopping for a D-Link DUB-H4 High Speed USB 2.0 4-Port Hub. It is a good choice if you are not going to plug any USB 1.1 devices into it. Read the reviews for any device you choose.
Oct 26, 2008 | Western Digital Passport WDXML800UE...
I-rocks IR-4300 4-Port USB Hub doesnt work
You shouldn't need a driver for it, Windows has bundled native drivers that will be enough to make it work.
Does anything else work in the port you plug the hub into?
Jul 11, 2008 | i-rocks IR-4300 4-Port USB Hub
i-rocks IR-4100 4-Port USB Hub Logo
292 people viewed this question
Top i-rocks Computers & Internet Experts
micky dee
Alan Rothery
Steve Allison
Steve Allison
Are you an i-rocks Computer and Internet Expert? Answer questions, earn points and help others
