Question about HP Photosmart M425 Digital Camera
Lens won't retract
Camera was dropped, when it was on, now the lens won't retract and the camera will only stay on for a few seconds.
  • 4 more comments
  • Anonymous Dec 16, 2007
    stuck lens- code 12 and 22 turns on only a few seconds to display error codes.
  • Anonymous Dec 18, 2007
    lens wont retract and when i turn on the computer it says "lens error:M425 13 (7f80)
  • mhutch Jan 04, 2008
    Camera has never been dropped or damaged, but for some reason the lens won't retract. Even though camera won't stay on more than a couple of seconds, I can manage to review photos already stored on the memory card.
  • Anonymous Jan 15, 2008
    me too. I kneed mine but caught myself before putting alot of pressure on the lens. When I checked it, the lens retracted into the camera & won't come out anymore. When I power it on, it only stays on a second or two , says lens error & shuts down.
  • Anonymous Jan 16, 2008
    GRR, i neeeeed my camera. if you turn it off & take the batteries out for like 15 seconds, and then turn it back on, the lense moves a little, but not all the way.
  • Anonymous Jan 17, 2008
    My cameras lense is stuck open, my friend dropped on a tile floor, and since then it's ben staying open and it keeps saying lens error m425-12 (7f80) i tired all the soultions on that website that that person posted but its not working, and i dont have the right screw driver to open it up. haha, but yea: /
  • 69 Answers
Here is a link to troubleshoot your issue. I hope this solves your problem. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00596002&cc=us&lc=en&dlc=en&product=1147733&dlc=en&lang=en
Posted on Aug 26, 2007
SOURCE:
Kodak easyshare c1530 won't turn on after slighty dropped
Hello Doris, You can "GENTLY" try to push the lens slowly back into the camera with the palm of your hand, note I said gently and slowly, do not use force !!! Then turn on camera and see if this helped, if not it is repair time.
Jan 26, 2013 | Kodak C1530 Digital Camera
Kodak m522 turns off with lens extended
Here are some troubleshooting steps that you can try:
Dec 09, 2012 | Kodak M522 Digital Camera
Lens won't retract
There are special springs, motors, gears, and guides inside these lenses.
If your lens won't retract, one of the above is bent, misaligned, or broken. There is not a 'quick fix' that can be applied in your situation since it is a physical problem, not a software malfunction. You can try to dismantle yourself but speaking from experience you are likely to make the problem worse. If you are unwilling to attempt repari yourself, either take it to a repair shop or upgrade.
Aug 18, 2009 | Cameras
Lens will not retract, camera was not dropped,
Leave the batteries out for a while and then try turning camera on..hopefully its resets the camera and retracts lens.
Jul 07, 2009 | Kodak EASYSHARE Z1285 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Samsung s700 camera lens won't retract
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 15, 2008 | Samsung Digimax S700 Digital Camera
Kodak V1003
Hello!!!
please remove your batteries and press the power button for few seconds and replace the batteries now and try switching on ...
Regards
Smilemaker.
Jul 19, 2008 | Kodak EasyShare V1003 Digital Camera
The lens on my camera won't retract.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens cover stays open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
The lens is stuck
my daughter sat on ours while it was on and the lens wouldn't retract. I tried the banging repair suggested for a stuck lens. After quite a few tries, it got the lens to retract when turned off but it wouldn't stay out when on, so i grabbed the lens and gently pulled it all the way out while it was on and it worked! (phew!)
Sep 15, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
HP Photosmart M425 Digital Camera Logo
91 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
