Sentry Safe Fire-Safe Personal Safe Logo
Anonymous Posted on Jul 04, 2013
Lost combination lost my combination numbers i have key and serial numbers
A1 Locksmith Burlingame
Level 2:
Scholar:
  • Sentry Expert 170 Answers
  • Posted on Nov 23, 2013
Sentry Expert
Level 2:
Scholar:
Answers
170
Questions
0
Helped
252701
Points
258
All you have to do is find your owners manual the sentry safe combination was posted in. Unless you locked it the safe as happens all the time. After all that is the safest place for it right. Or you can just call a locksmith service tech
Brinks Safe 5190. How to open with lost key and no combination.
You can't. This safe has a rotary combination lock and a failsafe key. The key is your insurance if you can't get in.
Call a local locksmith, for what will probably be destructive entry unless you have the serial number of the safe. A GOOD locksmith may also be able to impression a key for you. According to this you can get keys on proof of ownership.
https://www.lockpicking101.com/viewtopic.php?f=36&t=64109
How can I get the combination for our brinks fire safe model ...
Answers https://www.answers.com > Hobbies > Guns & Weaponry
Sep 15, 2023 - Get the model and serial from your safe as well as the key number. Call Honeywell @ 800-223-8566.
Sentry safe 1250 lost combination
I have a sentry safe 1250 .83 cubic and I have the key I was using the safe for awhile without the combination and just the key but now the key wont work and someone messed with the combination part which I dont know the combination i dont know what to do and I dont wanna trash this safe
Model 1310. How do I recover from lost combination?
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupFor over 80 years, SentrySafe has built fire-resistant safes that provide security ...Combo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership ... the notary process if you do not have your username, password, or combination. ... An override key is needed to unlock the safe.Missing: question
' Sentry® Safe ' SFW
Lost combination and also lost the keys,I need at leats replace the keys,I have the serial and number of the key
You will need to get in touch with the company. Be prepared to answer a lot of security questions.
S3470, no keys no combination
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
You will need to use the following link for combination retrievals: http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
2answers
Serial Number Location
Locksmiths agree there might not be a serial# but there is a key # Sentry Safes Keys. Lost your Sentry safe keys. just note your key #(on lock) It's above the keyhole example 3J2, C003B, H,
2answers
I have a sentry safe with a key and combination lock i have misplaced my combination now what
Sentry Safe lost combination. First, find your sentry floor safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
1helpful
2answers
Sentry safe v260 . have both keys but forgot the combination. how can i over write it?
If you have a "3 number combination" or have a "4 number combination you that you have NOT changed", you can send in your serial number in a notarized letter and $8 to: Sentry Group, Dept 200, 882 Linden Ave., Rochester, NY 14625-2784. (this info is in your Owners Manual under Lost Keys or Combination) If you don't have your Owners Manual you can download it from: http://www.sentrysafe.com/products/productDetail.aspx?s=130
If you have a "4 number combination" and you HAVE changed it from the original cobmination, the only solution you have is a locksmith.
2helpful
Lost combination for Sentry 1250
Lost your sentry safe combination. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe ( on paper tag near hinge) or under handle. just note your model # and the serial#. sentry safe lost combination and the opening instructions.
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
