I would first check to see if something has somehow got into the fan making it click and see if the fan is functioning. Possibly something overheated and burnt out. If you are comfortable taking this kinda stuff apart and have the room there are many test that can be made to determine what is blown. Or if you are not comfy with that call a technician or bring it to one even better. It is quite easy to have a bill around $250 - $400
SOURCE: RCA tv Making a clicking noise
This is a power supply problem it may be as simple as a blown fuse or as complex as a malfunctioning IHVT (Integrated High Voltage Transformer). Is it worth fixing, only you can answer that I would estimate the cost from $100.00 - $500.00 at least.
SOURCE: need a code for an RCA RCR312w universal remote-Emerson TV/VCR
To see RCA's code list you probably need their website but Emerson is one of several names now owned and built by Funai, who also builds Symphonic & Sylvania.
You might want to try those codes with your set.
SOURCE: My RCA model D52W20 will not fully power on when
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
SOURCE: I lost my remote control to my TV panasonic PV
There are a few universal remote controls that you can use, I have 2 philips remotes that work. One is model SRU4106/27, I believe i purchased that last year at Target, the other I no longer have the instructions to and there is no model number on the remote, but if the label says dvr's the remote will probably work. It is nice to get one with an advance button that has an arrow on the button, because Replay tv of that model has a commercial skip that can be used vs fast forward on other dvrs. The remote that I gave the model number for does not have the advance button, but the other thinner gray remote does have it and I purchased that one at Best Buy, but haven't seen them there in a while. You can also find them on ebay, just search replay tv on the search bar...Good Luck!
SOURCE: need password for rca tv
If you forget your password, you can reset it. Make sure the TV is off. Press VOL- on the TV's front panel and then CLEAR on the remote for approximately 5 seconds. The TV will turn on. Enter a new password the next time you access the PARENTAL CONTROL menu or the TIME
menu.
