Question about RCA HD44LPW165 44" Rear Projection HDTV
Tv intermittenly works
My tv just stopped showing a picture. There is sound, but the green power light blinks. After a couple days, i turned it on and it worked again. Now it doesn't AGAIN. I checked the lamp, and it is fine. I did notice some minor "squealing" cominf from or near the lamp housing. I live in a 100 year old house with poor wiring. Could it not be drawing enough electricity?
  • Anonymous Dec 04, 2008
    Squeaking noise and no picture.
    Problem Solver:
  • 5 Answers
The sqealing noise is going to be one of the cooling fans or the color wheel. The color wheel is famous for making noise. Some are louder than others. The most likely culprit is going to be your ballast. You can find them on Ebay for under 100 dollars. You can also find a spare bulb for around 85 dollars. I made it a habit to keep one on hand just in case it went out right in the middle of something.
Posted on Mar 18, 2009
    Sergeant:
    Champion:
  • 375 Answers
The squealing is the power supply off frequency its trying to produce b+ voltage there must be something loading down the b+
Posted on Aug 25, 2007
SOURCE:
Green power light want stop blinking
Problem is with one of the circut boards in the tv, It will have to be replaced.
Oct 21, 2012 | Sanyo DP19647 19 in. LCD TV
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony- KDF-50E2000
Have you replaced its Lamp?
Symptoms shows TV needs new lamp.
Please always buy original Sony lamp for replacement.
Mar 15, 2009 | Sony KDF-E502000 50" HDTV
TV turns on the on/off light turn red and green coninually
IT MAY SOUND WIERD BUT SAME HAPPENED TO ME, CHECK THE POWER CORD, NOT WHERE IT GOES INTO THE WALL, BUT WHERE IT GOES INTO THE TV, TRUST ME, JUST PUSH IT IN MORE.
Jan 30, 2009 | Akai PDP-5016H 50 in. HD-Ready Plasma...
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No picture; No sound
how many times does it blink red? It should blink so many times then stop then blink again. how manty times does it cycle?
Jan 02, 2008 | Sony KDF-E42A10 42 in. LCD Television
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
RCA HD44LPW165 44" Rear Projection HDTV Logo
110 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
