Heating & Cooling Logo
Anonymous Posted on Jul 03, 2013
My kenmore elit 10000 has leaked what not a little but lots since the day it was purchased. What are we doing wrong?
Anonymous
Level 1:
New Friend:
  • Contributor 60 Answers
  • Posted on Jul 04, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
60
Questions
66
Helped
24011
Points
88
2answers
I purchased a Kenmore Elite Coffee maker last year and now water is leaking from the bottom. I noticed it has a five year warranty on it . how do I go about getting it replaced or repaired?
Claim using this phone number. It says 2 years warranty, but the product link does say 5 years.
WARRANTY SERVICE
To obtain the warranty coverage stated below, return defective product with proof of original sale to Kenmore (Transformco) authorized retailer from which it was purchased. Call this number to obtain the warranty coverage stated below: 1-800-265-8456
KENMORE LIMITED WARRANTY
FOR TWO YEARS from the date of original sale this appliance is warranted against defects in material or workmanship when it is correctly installed, operated and maintained according to all supplied instructions.
WITH PROOF OF ORIGINAL SALE a defective appliance will be replaced free of charge. If replacement is not available, the retailer will provide item price credit usable for other purchases from that retailer.
This warranty does not cover expendable parts that can wear out from normal use within the warranty period.
This warranty is void if this appliance is ever used for other than private household purposes.
Kenmore Elite Brew Coffee Maker with Burr Grinder
Koolatron https://www.koolatron.com > en-ca > products > kenm...
Kenmore Elite Grind and Brew Coffee Maker ; Power Type, 120 Volt ; Product Weight, 11.50 lbs (5.29 kg) ; Color, Silver, Black ; Warranty, 5 year limited warranty.
$319.00 · ‎In stock
Kenmore Elite Programmable Coffee Maker ' 12-cup
Koolatron https://www.koolatron.com > products > kenmore-elite...
Best of all, Kenmore Elite products are backed by a 5-year limited warranty for your peace of mind.
Our Kenmore Elite french door bottom freezer, automatic icemaker, no water/ice dispenser on the door - is leaking quite a bit - had to mop up the floor three times today. first time it's happened since...
Check for cracks in the water supply tube from the house plumbing valve to the ice maker. Could also be the valve itself.
Turn off valve for a day to diagnose which.
I have a kenmore elite front loader washing machine and the problem is that the rubber gasket ripped causing water leak
Nothing to do there but replace it. Call sears service with your model#, serial# and date of purchase to order one.
1helpful
My kenmore elite washer has a very loud banging noise when it spins
U will need to remove the washer drum and check the washer drum stablizers and the washer drum bearing, do this to see what is wrong and how far u need to go in this repair.First open the door and spin the inner tub to make sure the tub spins freely, if not you have big problems.
If it does then remove the lower front panel. There are 3 screws along the very bottom of this panel that you can remove and then the panel will come off. Check to make sure the shocks are not cracked or broken under the tub. If not and the unit just recently started shaking a lot, then replace the shocks as they are probably worn out. If it's been shaking since the day you've gotten it and it just seems to have gotten a little worse, then purchase Shake Away pads which are specifically designed for front load washers to sit under the feet of the washer and reduce vibration dramatically.
I have a top loader kenmore elite washer that is leaking. The service guys have replaced everything from valves, tub ring and the fabric softner dispenser but its still leaking Help
Hi, Did they check the pump seal or the hoses. Does it seem to leak from the front center? Is it leaking while filling or during agitation or spin cycle? Are you getting water every load and is it a little water or a lot?
Please forgive all the questions, I have to ask.
Questions I need to ask in order to assist you as best I can.
Vic
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
3helpful
2answers
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Kenmore Front Load Elite Washing Machine
You must ensure the boot is properly seated on the outer tub, There is a groove in the lip of the tub and the boot,make sure grooves are fully mated. Also try getting a new clamp; the screw can back out releasing the tension,also fold the excess clamp that passes through the screw over backwards preventing the clamp from loosening, a few dabs of good super glue helps too and can still be removed (dont use much a few drops in four places is sufficent).
Top Heating & Cooling Experts
Paul Carew
john h
