Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
32 color i had a problem i had reinstall my windows then my colou qality was 32 now it is only 16 help
    Problem Solver:
  • 17 Answers
You can this in display properties on desktop you can set it to 16 or 32 bit. But there may be another problem ie., if you have not installed the display driver software if it is not packed with your windows. install the driver from the driver cd provided when you bought the pc.
Posted on Aug 25, 2007
  • Devendra Sakibanda Aug 25, 2007
    ooops forgot please rate my answer if it is any sort of help pls :)
SOURCE:
Monitor result change 16 colors
One of your applications are changing your color scheme to 16-bit because it isn't compatible with your OS or graphics card. Try reinstalling your drivers, then disabling programs one by one when the problem occurs. For example, games that used to run on windows XP or older tended to change the color scheme and resize the monitor to 480p.
May 19, 2014 | Nvidia Computers & Internet
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
What is compatible with Printmaster 10?
  • 133 MHz or faster Pentium processor
  • Microsoft Windows 95, 98, NT 4.0, or 2000
  • 32 MB RAM
  • 164 MB hard disk space
  • 4x CD-ROM drive
  • 16-bit color with 800 x 600 display
  • Windows-compatible sound card and speakers
  • Works with most popular printers (monochrome and color) supported by Microsoft Windows
  • Internet access for online features
  • The above are the requirement for printmaster 10....Hope this will help you...
    Nov 13, 2009 | Broderbund Print Master Silver 16.0 for PC
    How can i upgrade my 16-color to 32-color
    Are you referring to color scheme? If so, you should be able to right-click on an empty space on the computer desktop, choose Properties from the menu that appears. Then, in Windows XP, choose the Settings Tab. You should see a drop down menu on the lower right titled Color quality. In the drop down menu you can choose 16 bit, and should have a selection for 32 bit. Select the 32 bit, click Apply. Then the screen should change to that setting and ask if you want to keep those settings. Select OK and you should be good.
    Sep 28, 2009 | Computers & Internet
    IS THERE A SPECIAL CARTRIDGE FOR PHOTO PRINTING. MY PRINTS COME OUT WITH A BLUE TINGE TO THEM my printer takes No. 32 black and 33 colour..
    Sir,
    Your problem is not of specially cartrigde but what you need is a special Paper which is made to print Photos and other colour full pictures. If you see is not this problem then there is chance that your cartridge is leaking from blue color point as there are three inks in color cartridge Red,Blue and yellow , than you need to replace you colou cartridge with new one .
    Aug 28, 2009 | Office Equipment & Supplies
    Ir 3200 colour copier copy qality very ow how to adjested copy qality
    I do not know if you are know, that this is copier wich is predicted for small office copy, for color is only good for few charts or small pictures.
    In most cases the problem is with grey colour, red is also strange.
    You can try next:
    1 Clean the beaneath copy glass
    2 Clean scaner
    3 Under user mode do colour graduation adj
    4 if you want you can under service mode clear R-CON and reenter factory settings, but for this call service.
    It also can be that copier needs to be replaced developer assys or drum or itb...
    Dec 17, 2008 | Canon iRC3100 Printer
    Copy not good
    under user mode there must be color or gradation adjustment, i belive under printer prop.
    How many copies do you have?
    After 100000 copies you will need to change developing units, and clean drum sensor, or replace drum.Call service.
    Dec 17, 2008 | Canon imageRUNNER C3200 Color Printer
    Video driver for Dellm770 with Dell Optiplex110 - running Windows98
    video si dependent on the video card you have. WIn98 is capable of 32 colors, therfore, you need to get a video card that is capable of giving 32 bit color.
    as fa as digiital pic, you need at least 32bit if not 256bit. which win98 will have a hard time to comeup with.
    I think it is time to upgrade.
    Sep 26, 2008 | Microsoft Windows 98 for PC
    I just reinstalled windows 98se but it only has 16 bit color is their a way to get 32 bit color
    You need to install the Video driver for your graphics card to get full use of your display card with full feature.
    • There might be a motherboard CD shipped with your PC, it might include driver for your all devices.
    • Just put that CD and install the required drivers.
    • If you don't have any CD like that, then you should go to your manufacturer's site and make download driver for your device for Windows 98.
    Thanks
    Iqbal
    Apr 20, 2008 | Computers & Internet
    Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
    35 people viewed this question
    Top Microsoft Computers & Internet Experts
    Ekse
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
