Question about Vivitar ViviCam 4100 Digital Camera
Transfer picture from internal memory to sd card
How do i do that
  • mariejoannie Aug 30, 2007
    was very helpful thank you
Insert memory card turn camera on press menu function , press ok to copy to card cilck on execute. hope it helps
Posted on Aug 27, 2007
SOURCE:
How do I transfer pictures from the internal storage to a sd card?
hi rednpat986.
this is all i could find,if this does not work go to the link at the bottom.
How to transfer photos from camera internal memory to SD card? Follow these steps:
  1. Insert a memory card into your camera.
  2. Turn on your camera.
  3. On the camera, press the Review button then the Menu button.
  4. On the Setup tab in the menu (your menu tabs might be named differently), select Image Storage.
  5. Select Internal Memory.
More items...
Transfer pictures from internal memory to a card - Kodak Support
camera How do transfer pictures from the internal storage to sd card...
Nov 05, 2017 | Cameras
Dmc ls80 transfer
Most cameras don't have enough internal memory to take more than 1 or 2 pictures internally. Picture transfer is normally accomplished via usb cord. The process begins when you plug in your usb and power on the camera. You have to navigate between internal memory and SD card in windows explorer.
Jul 22, 2014 | Panasonic Lumix DMC-LS80 Digital Camera
How do I take the pictures out of the internal memory and put them on an SD card so I can take them OUT of the internal camera memory?
Use the "Copy" command in the Playback menu to copy the pictures from the internal memory to the card. Once the pictures have been safely transferred to your computer, format the internal memory to clear it.
Jun 19, 2012 | Nikon Coolpix S6100 Digital Camera
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
How to transfer pictures from camera to sd card
The pictures that are stored on your camera memory cannot be transferred to the SD Memory Card. They must be downloaded to your computer first and then transferred via a card reader, if you intend to get them to the SD Memory Card. The two memory areas, internal and SD memory work separate of each other and the camera only operates from one. IF the system detect SD Memory than that is where the images are saved, if not, they automatically go to the internal memory.
Here it the manual for your camera:
http://www.pentaximaging.com/files/manual/E30_E.pdf
May 18, 2011 | Pentax Optio E30 Digital Camera
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
Transfer from camera memory
there might not be a way of transferring picture within the camera. However the SD card _should_ have resolved the memory full issue. Plug the camera into a computer with its USB cable. Transfer the pictures to the computer and delete them off the internal memory. Assure that your SD memory card is functional by trying it in another camera or in the slot on a computer.
Nov 30, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Westinghouse 7" lcd picture frame internal memory not recognized
You can copy files from internal memory to sd card only. Its one way data transfer.
Sep 05, 2008 | Westinghouse 7" LCD Digital Photo Frame
Vivitar ViviCam 4100 Digital Camera Logo
59 people viewed this question
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
