Back to:
Tags:
GE JBP60 Electric Kitchen Range
"Locked Door" flashes after interrupting self clean...
posted by robertkbrown on Aug 25, 2007
Forgive me, but I didn't see a link to post a reply, just a comment so I'm posting this reply as a new post.
My response to catriver's response to my original post was:
Thanks Catriver,
I think I'm doing something wrong. I pull the power cord and hold the cooking time and delay start pads together while my wife plugs the range back in. At this time, the screen says 72 (degrees) and "test". I press "8" and nothing changes, the screen still just says "test. I tried pressing and holding the "self clean" pad, but nothing happens (tried holding it for about 10 or 15 seconds). The whole time this is happening, it's still flashing "Locked Door".
What am I doing wrong?
----- My original problem -----
My wife was cleaning the face of the range when she accidentally hit the self clean button. Not knowing what to do, she just reacted and opened the door.
Initially, the locking mechanism had moved over into the lock position so we couldn't shut the door. I figured out how to raise the lid and get into the locking mechanism to move it back manually to the "open" position so we can at least shut the door now. However, it still flashes "Locked Door" and we can't do anything with the stove portion of it.
I suspect there's a solenoid that still thinks the mechanism is in the locked position that needs to be reset. I've tried running it through the self clean cycle and recycling power on the unit. No change.
Suggestions?
TIA,
Robert
----- catriver posted the following -----
Robert, see if you can get it back home by using the test funtion. Kill the power to the oven. Turn it back on and on the control press and hold the cooking time and delay start pads together. While hold these keys, press the number 8 pad. The words test should appear in the display. Now press and hold the self clean pad and it should cycle the cam through the whole process. Here is what you should see.
1 test (unit is in unlocked position
0 test (moving toward latched pos.
2 test (latched position
0 test (moving toward unlocked pos.
1 test (unit is in unlocked pos.
Press cancel to exit the test. See if this gets you going again, let me know, Catriver
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 26, 2007
Thanks for Trying (70)
MakikiChris
Rank:Wiz Wiz
Rating: 81%, 86 votes
Hi robertkbrown...you may want to try to following steps.....good luck my friend...chris
If ?LOC DOOR? is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
3. While you hold the door jamb switch in this position, complete the following steps.
4. Press the Clean pad, wait 10 seconds.
5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
6. Wait 10 seconds for the display to clear.
7. The door should unlock and there should not be a need for service.
Manual Switch
1. Press the Clean pad.
2. Close the door.
3. Slide the latch to lock the door.
4. Hit the cancel button immediately.
5. Unlock the door.
Rating Locked! (?) robertkbrown has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on "Locked Door" flashes after interrupting self clean (follow up):
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
Kitchen Ranges
My wife went to self clean our frigidaire professional...
Kitchen Ranges
Whirlpool Gas Stove Model #SF362LXSB0 Both the broiler...
how to clean betwen oven glass door
the electronic kepad says locked , nothing on range works
i used our oven today and turned it off afterwards yet it...
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
