Question about Samsung SGH-D500 Cellular Phone
Bluetooth and infared
Every time i go to turn on my bluetooth or infared it says "bluetooth activate error" how do i fix this
  • Dennis Leefarr
    Dennis Leefarr Dec 10, 2007
    Phone in as new condition,has not been dropped or damaged in any way.
    Works perfectly in every way other than when one attempts to engage IR or Bluetooth a notice appears saying 'Failure to Activate'
    I am seeking a solution to this problem from someone who has experienced it and has managed to overcome the problem.
    So far it would appear that no one has a solution ,or has not been prepaired to share it with the many other people experiencing this problem.
    Problem Solver:
  • 6 Answers
How does one check the 'bt mac address' ?
Checking the IMEI is of course not a problem.
There has to be an answer as so many of these D500 phones have this problem.
Unbelivable suggestions such as pressing hard on the IC near the battery connections has been alledged to have cleared this fault.This suggestion came from two seperate sources. It may suggest poor connections on that IC which become disturbed by pressing?
Dennis
Posted on Dec 10, 2007
  • 39 Answers
Check your imei and bt mac adress.if they are not paired,bt and ir port will not work.other thing that may be wrong is bt module itself,that got damaged after the fall of the phone
Posted on Sep 03, 2007
SOURCE:
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
How do I turn on the bluetooth on my Z T PAD
You must turn on the tablet's Bluetooth radio before you can enjoy using any Bluetoothy peripherals. Here's how to activate Bluetooth on an Android tablet:
  1. Open the Settings app.
  2. On some Samsung tablets, touch the Connections tab.
  3. Ensure that the master control next to the Bluetooth item is set to On.
    Slide the icon to the right to activate.
    When Bluetooth is on, the Bluetooth status icon appears. It uses the Bluetooth logo.
To turn off Bluetooth, repeat these steps, but slide the master control to the left, to the Off position.
You'll also find a Bluetooth switch in the tablet's Quick Actions.
Dec 20, 2014 | Tablets & eReaders
I am trying to activate my samsung E250i bluetooth but is says bluetooth activate error
I had the same problem with a Samsung L700. Turn it off and then on, it should help. If not visit a Samsing Service Point.
Jan 24, 2012 | O2 Samsung SGH-E250 Cellular Phone
I cannot activate my MSI EX465 Bluetooth, when I pressed on the Function Key then the Bluetooth Key the light for the Bluetooth is not even turning on, tried downloading a Bluetooth Driver that includes a...
hey... i do have also that kind of laptop, and finding my self answers on how to fix it. I did what you have done, but still i can't figure it out.
inform me pls if you know the solution. I'm thinking that OS compatibility was the problem.
some links says it's "windows mobile center", this is the one I'm trying now.
cheap web hosting @ 0$/month http://hostscripter.com
Apr 01, 2011 | Computers & Internet
Bluetooth activate error
HI,
Please pair the device with the phone? if not then read the manual of the bluetooth and pair them first.Also try turning the cell off & removing the battery and then turn oin again to see if the issue is solved.
Feb 10, 2009 | Samsung SPH-M610 Cellular Phone
Insert SIm, Unable to backup data
A sim is required to run any part of the phone.
Mar 06, 2008 | Nokia 6103 Cellular Phone
Bluetooth problem...
same thing happened to mine. I already bought a new battery, but it seems that the problem is not on the battery. This bluetooth error appears to be the problem for draining my battery.
Dec 22, 2007 | Samsung T809 Cellular Phone
Samsung SGH-D500 Cellular Phone Logo
156 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
