Question about Toshiba Satellite Computers & Internet
Short circuit Hi I have a Toshiba satellite P745-S4217. I accidentally short a chip located right in front of the battery and beside the wifi adapter and where the power button ribbon is attached. After coming in contact with a piece of metal there was a small spark and now the pc would turn off immediately after the power LED comes on. So is there anything that can be done or is it permanently dead?
    Sergeant:
  • Toshiba Expert
  • 278 Answers
It is may be blow off protection resistor or capacitors, pls check the area with multi meter
Posted on Oct 06, 2017
mewms_14904
  • 1027 Answers
SOURCE: ac led blue battery led amber will not power on
Check with toshiba, they have an update on this link
On my Toshiba M105-S3051 the reset switch is a pin hole above and to the left of my microphone jack on the front.
Posted on Mar 27, 2008
knotbeerdan
  • 413 Answers
SOURCE: Hi, I need some help (BIOS locked)...
ok i found a couple more things...apparently you dont have to remove the battery.. I found this site that tells you two "jumpers" (solder squares) C88 i believe under the network card. But if you follow this link and follow the directions it will get you going again.
I don't know exactly at what stage you are at and i hope i didn't cause any trouble but this normally is how we take care of this problem. Unless once in a blue moon we come across one like this.
http://www.paralaptop.com/toshiba/fixing-bios-password-locked-on-toshiba-satellite-a105-s4014.html
Posted on Jan 17, 2009
  • 99 Answers
SOURCE: Toshiba Satellite L25 series laptop doesn't power on
its a fried motherboard. any questions you can email me at meanness628@aim.com
Posted on Jun 30, 2009
SOURCE: Toshiba satellite u400 Power led amber
Bad Mother Bad
Posted on Oct 27, 2009
  • 128 Answers
SOURCE: Toshiba Satellite 1905-S301 PC Notebook will not
Hi! You may want to toggle the function button designated for turning the monitor on or off. Press FN button together with th efunction button that has a monitor image on it. some system uses F2 of F3 button to do this. (Example: press FN+F3 or FN+F2 button together once while computer is on to turn on system display)
Posted on Jun 08, 2010
Short Circuit
Hard to say, take it to a Qualified Computer Tech, perhaps it can be salvaged? The tech can use a multimeter to ID the blown component and suggest a fix. Problem is, with most electronics these days, it's sometimes cheaper to buy a new Laptop, your Laptop is getting a bit out-of-date, maybe it's time to let her go? I have a Toshiba M35X-S311 that someone gave me, it overheats and shuts down. Your has similar specs. Trade up would be my advice.
Jul 03, 2013 | Toshiba Satellite L25-S121 Notebook
Add ram Satellite u845
Power down your Toshiba Satellite.
Unplug it from the wall.
Turn the machine over and remove the battery.
Locate the RAM compartment cover, which is usually located somewhere in the middle of the underside, and is about 4-by-4 inches.
Unscrew the RAM cover screw with a Phillips screwdriver and set aside.
Ground yourself by touching a metal object.
This will release any static electricity built up in your body, which can harm computer chips and components.
You can also use an anti-static wristband while you are working.
Remove RAM modules if needed.
This is most likely if you are upgrading the present RAM capacity with a larger RAM chip.
Press your fingers on the clips on either side of the chip to pop it out of the socket.
Pull the chip out of the RAM compartment, holding it by the sides of the circuit board rather than on the chip.
Insert the new RAM module into the socket. Align the RAM module so that the notch lines up with the tab on the side of the socket.
Gently lower the module into the socket. Press into place with your fingers.
Replace the RAM compartment cover. Insert the screw and tighten.
Replace the battery and secure with the lock.
Plug the Toshiba Satellite laptop back in and power up the system.
The upgraded RAM should be automatically recognized.
hope this helps
HOW TO INSTALL MEMORY UPGRADE TOSHIBA SATELLITE LAPTOP
not sure if this is the right laptop
http://www.youtube.com/watch?v=RdCzsjDp_lc
Oct 12, 2012 | Toshiba Satellite U845-S402 14" Notebook...
I Accidentally Disabled the Built-in Microphone on my Toshiba Laptop and I Can't Get It To Work Again?
There is a built-in microphone located beside the built-in web cam. however, if the microphone should stop function, or you want to use an external mic, there is a mic input jack beside the eSata/USB port.
Jan 24, 2011 | Toshiba Satellite L500 Series Notebook
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
Were is my wi fi application on my computer
My Toshiba Satellite has a little on off switch in the front just below the power lights, the actual wifi adapter is located inside the computer, but you can look in the control panel, click on system, then click device manager on left side of screen at top open that up and go to net work adapter and click the little + mark to expand and it should list your wifi adapter there if it is installed.
Hope that helps and please do not hesitate to ask for further advice and please rate/score, etc.. the advice I gave..
Stormi
Nov 15, 2010 | Toshiba Satellite Pro L300 Notebook
My Toshiba satelllite A 305-S6905 System unit laptop just stopped charging , it does not switch on. only yesterday, it was working fine with no problems. it is just two years old .
Please check your battery for right voltage. if the voltage is down check the voltage in your adapter. If there is no voltage in the adapter then you might have to open check the continuity of the cord, normally this cord shorts and the adapter cutts off supply due to a high current error. So if there is shor tremove or other wise check the SMPS circuit for failed components, fuse, recifier, capacitor, driver. However if adapter works there must be supply at the battery terminal of the laptop, if not you have a failure in the charging circuit in the laptop. Hope you check this out one by one. Hope I could help. Good day
Aug 14, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A55-s1066 need help Loacting Bios Chip.
you need to remove all at same time and memory modules too, and after remove the cmos battery, try to find a passw clear switch on the motherboard nearby cmos battery.
Feb 14, 2010 | Toshiba Satellite A55-S1066 Notebook
Toshiba Satellite A105-S4048 problem with AC Adapter When I turn the laptop on with the AC adapter, after checking the BIOS freezes and does not boot Windows. If I turn the laptop in only with battery boot...
There's not much you can do. The problem is definately with your motherboard. I'd recommend a bios update, but normally you can ONLY run a bios update if the battery and the ac are both plugged in.
This problem is pretty common among Toshiba's A105 and P105 models.
Besides replacing the motherboard there's not much you can do.
Sorry.
Mar 10, 2009 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
