I have a gas Amana dryer, Model LGA30AW, and in the Auto cycle it seems to never shut off. The clothes are really hot when I remove them. I have replaced the limited thermostat and the sensor thermostat. I am running out of items to think of. The timer works in the other cycles so I do not think it is the timer. What does the heat thermostat do? I need some help as the dryer is about 10 years old.
Try to get the manual for the dryer you got and locate the moisture sensor if this sensor is bad what happen is that the automatic timer thinks that the clothes still wet and continues to dry once the sensor detects no moisture then it shut off the dryer normally is located behind the dryer on the exit line of the air duct and tested for conductivity and see if is good or not
