Question about Acer Aspire E380-UD420A (ASE380-UD420A) PC Desktop
Lack of set up instructions as to what goes where on new tower. I am left with a piece of kit I dont know where to plug it in, it is a small item around 15mm long attached to wire and plug possibly a sensor of some kind.
    Problem Solver:
  • 20 Answers
Plase give more details. Your idea is more wast. Ask any your friend that wht it is so that proper solution can be provided.
Posted on Aug 25, 2007
Fuel line placement on the walbro wt 673 carb
This is superb, the one I'm trying to fix has been piped up wrong, the primer bul is pushing the fuel through the carb.
It will start and idle, but when ypu open the throttle it dies, from lack of fuel.
May 21, 2012 | Homelite Garden
Not getting spark
need more info (need to know what type of ignition system your vehicle has: (1) traditional ignition coil /distributor system, or (2) electronic ignition, but lack of spark problems are usually a faulty coil
on traditional vehicles, and on the newer electronic ignition cars, total lack of spark would be
a faulty ECM (electronic control module) - partial lack of spark (diagnosed with a HEI (high energy ignition) spark tester kit), would be caused by a faulty coil pack (in the waste spark system), where
there's 1 coil pack for every 2 spark plugs.
I bought my HEI igntion testere kit for $20, but Harbor Freight sells a similar unit for $10.
Hope this helps.
Dec 27, 2010 | Ford F-250 Cars & Trucks
Back firing, seems like lack of fuel, need to know where both filters are
Back firing is caused by improper firing order or bad timing belt or chain.Verify spark plug wires are on in correct order. If no one has been changing wires, check that when harmonic balancer is lined up at top dead center that rotor in distributor is lined up to tower that goes to plug wire that goes to number one cylinder. First plug in front on passenger side. If it is off your chain or belt depending on motor needs to be changed.
Sep 24, 2010 | 1991 Ford Mustang
Harman-Kardon HK695-01 Speakers Connection Quesion
According to the manual
leave the black connector unconnected.
Hope that helps.
Oct 02, 2009 | Harman Kardon HK695 Computer Speakers
I recently installed a 3 mode rapid fire mod kit.It works perfectly apart from now the left and right action on my left analog stick wont work.Can anyone help me.
Unfortunatly this was completely my own fault through lack of concentration and not paying attention. I let the smallest piece of solder fall on the analogs components. All I done was scraped it off. Problem solved.
Sep 09, 2009 | Sony Playstation 3 (PS3) Console
Kenmore washer 100.92380200 upper agitator not turning
Just fixed mine. You will need an agitator repair kit. It comes with cover seal, bolt seal ratchet pieces and thrust plate for the bottom of upper agitator. Remove fabric cup and cover underneath. Remove bolt and upper agitator. Simple fix. New parts have instructions to repair. Get the correct model number and buy it from an appliance parts place. Around $20.00 retail.
Jun 15, 2009 | Kenmore Washing Machines
Bath waste
! goes over the threaded piece that screws into the piece that goes under the tub...and the other goes between the tub and the waste assembly thereby creating a sandwich with one on top and one underneath the tub....then screw the piece down tight through the tub and into the waste assembly and your good to go.....
Good luck and thanks for rating my effort.....the Fang.
Mar 25, 2009 | Lefroy Brooks BATH WASTE KIT - LB1370-ST -...
Lack of instructions for Tevion/ My Guide Sat Nav
I have the manual for the MyGuide 3000GO. Send me your e-mail address so I can give it to you.
Mar 04, 2009 | MyGuide 3000 Portable Sat Nav Car GPS...
How to set dip switches in highest point for multi speed blower. Have gas furnace (amana) and heatpump(amana) both 4 ton cap. My hp keeps cycling and asume is the lack of airflow.
Yes, it could very well be the lack of air flow, how to set the dip switches, need more info on the setup or diagram or instructions, write me at, I will try to help you
Sep 16, 2008 | Amana Heating & Cooling
Acer Aspire  E380-UD420A (ASE380-UD420A) PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
