Question about Nokia N95 Cellular Phone
Operating my phone
I inserted my sim card. code was accepted but i only get a blank screen and the phone is not responding
  • 3 Answers
Re: operating my phone
Hello Nenieco, try starting the phone WITHOUT a sim card in it. It will then say ´´Do you want to start phone in off line mode´´ PRESS YES. If the phone then functions in off line Mode, you know that the sim car is damaged. If it will not start up at all, then you need to put your phone in for repair. Good Luck! David C3PO
Posted on Sep 09, 2007
0 characters
3 Points
Unlock my phone
If the Nokia X6 16GB phone,displays invalid sim card message on the screen it is locked to some network.Please find out the network and country it is locked now.If it is locked to network,it will not accept other network sim card.But you saying it is accepting other networks sim card.How many network sim card have tried inserting in it?If you tried only one network sim card and it accepted that it is locked to that network.You can also try using some other network sim card.If it displays invalid sim message again.It is under network lock.To unlock it use unlock code.Visit the site get code and unlock it easily.
Jun 11, 2013 | Nokia X6 16GB Cell Phone
SIM Card
If the Dual SIM accepts GSM networks, insert your T-mobile SIM and use it. If the mobile is locked to a GSM network it wont accept other SIM cards. You have to unlock it to use. You can unlock it using codes very easily. Visit to order your unlock codes.
Jun 27, 2012 | Cell Phones
Want to change my sim card in my phone , but when i insert the sim card the phone does not recognise it and says to insert sim card
Hello there,
If your phone is not accepting any other sim card, then it means the phone is sim card secured lock or protected, there are some phones that do not accept any other kind of sim card apart from that which they are made for.
For instance a phone made for vodafone purposes cannot accept etisalat sim cards, it will only accept vodafone sim card. Therefore that is what you are facing with the phone.
Take not, if you insert similar kind of sim you were iniially using, it will accept it.
That is why you cannot use another kind of sim on the phone.
Thank you for using fixya Caseytech
Jul 05, 2011 | Samsung Cell Phones
Unlock samsung s3650
Follow the instructions given below & unlock your mobile by getting unlock code in this site gain solution ..
Warning : Do not enter any wrong unlock codes on your Samsung S3650 Corby mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung S3650 Corby mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung S3650 Corby with a NOT ACCEPTED SIM Card.
2 - Samsung S3650 Corby will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung S3650 Corby shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung S3650 Corby.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung S3650 Corby is locked to.
CODE: Its the unique Unlock Code for your Samsung S3650 Corby.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung S3650 Corby.
Mar 15, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
It sais "phone freezed"- enter password
default passwords are 0000 , 1234, 00000 , 12345 . If the phone is frozen , try removing the phone battery. That should reset the phone.
Sep 18, 2009 | Samsung SGH-E390 Cellular Phone
Second SIM not working
Settings>Dual SIM settings>Select "Dual SIM open>click OK
Jun 11, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Unlock Code
Cingular Samsung SGH-C417 unlocking solution
Insert a non accepted sim card into the phone
1.First with SIM in phone at WRONG CARD screen ENTER on the keypad
*2767*3855# (wait 10-15 seconds) phone will reboot(restart)
2.When phone completes reboot ENTER
*7465625*638*00000000*00000000# (Network Lock Personalized)
#7465625*638*00000000# (Network Lock Deactivated)
i found that on the web it may help
Apr 01, 2009 | Samsung Cell Phones
Please help me
ok do one thing put one expired sim card in your cell then it surely works it will not freeze i think ...
after that give restore factory settings(reset) as you access menu ...
(if you were able to access the menu previously then no need of this expired sim card ...)
after giving restore factory settings then all your firmware problems will be solved & the phone will not freeze like previously so just insert the sim card whose network must be unlocked & insert that code ....
in case if you couldnt do the restore factory settings then just
insert this codes with out sim(any one of them will surely reset your cell)
in this one of them will reset your phone after that insert that sim & insert the previously told unlocking code...
that s it ....
thank you
please rate my solution
Jul 04, 2008 | Cell Phones
Unlock MOBILE / SIM card LG KG220
i bought my phone throught e-bay too i got optus sim card ask me about secuirty code (sos) i just put 4 zero ( 0000) the phone accepted and un locked try that
Feb 22, 2008 | LG KG220 Cellular Phone
I have a nokia cell phone and when i insert a vodacom sim card it says the sim is not accepted. so is it locked for the sim card or what can you help me?
Three reasons for this:
1) If you have just obtained the phone and have used your own sim card, your phone is more than likely locked to a particular network. That means that it will only work with a sim card that matches that same network. If you try to use a sim card for a different network, the phone will tell you the card is not accepted. You can obtain unlock codes for most cell phones so that any network will operate.
2) The phone, sim card or both are on a lost or stolen list and the phone has been blocked. If this is the case you can do nothing unless you are an expert. My advice would then be to take it to your local police.
3) Or the sim card is faulty or has poor contacts. You can try gently rubbing the gold coloured contacts with a cotton bud.
Feb 16, 2008 | Nokia 1100
Nokia N95 Cellular Phone Logo
56 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
