Question about Jenn-Air JMW8330DAS Stainless Steel Electric Double Oven
Microwave not working
Themicrowave is not working at all; no power. The oven works fine. i checked the home breaker and it is fine. is there a fuse in the unit to replace? If so, how do I get to it?
  • elliotlewis Aug 26, 2007
    Thanks for your response! Ok, this is going to sound really dumb however the entire unit is built in and thus the plugs are behind the unit. I am surprised they did not have any easy way to unplug the unit. Is there an easy way to take off the trim around the microwave? It looks like a few screws on the side will allow me to remove it. The problem is that the builder of te house left very little room to get a screw driver in.
    Elliot
    Thanks, I will let you know shortly!
  • 725 Answers
Hi your microwave is a total separate unit. first check to see it it is plugged into your oven. If it is then to check the fuse. You will have to remove the cover first unplug the microwave remove the screws from the back and side ...pull the cover to the back remove cover. there is a small board on the right side toward the back with a dark gray cartridge fuse. that is you main fuse. you can check it with an ohm meter to make sure it is blown... let me know what you find out?
Posted on Aug 26, 2007
  • Franklin Ouchida
    Franklin Ouchida Aug 26, 2007
    yea the trim around the microwave will have to come off. to get the microwave out. I have see builders tile wall units and dishwashers in so the only way to get them out is to chip all the tile away..good luck at getting the screws out...let me know..
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
No power after self cleaning
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Dec 14, 2013 | LG LWD3081ST Electric Double Oven
Our Belling Touchtronic hob wont now turn on. Have checked wiring on the mains and fuses but make no difference. Any ideas? Was fine yesterday and had shown no signs of intermittent working
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
5.
Dec 27, 2012 | Belling Ovens
Microwave stopped working after an apparent surge. Tried unplugging, plugging back in, checked breaker panel. Electrical for the microwave works. Think it must be a fuse in the microwave b;own? If so,...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 12, 2010 | Ovens
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
I have a ge jkp86 electric oven the oven will not heat up .the microwave works and all displays work
First thing that comes to mind is to make sure you are getting the correct voltage to the oven, you need 220 / 240 volts, check your breakers, fuses ,etc.
It is possable for the microwave oven to operate even if the power supplied to the oven is only 110 volts, but that low of voltage is not enough to power up the ovens heating elements.
If all seems well there, then maybe the oven element has failed / shorted ?
Good luck !
Jan 27, 2010 | GE JKP86 Electric Double Oven
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Sep 19, 2008 | Ovens
GE. Microweave Oven, Model JVM 1090
If your microwave won't start and the display is blank and unresponsive, the issue may be with the ceramic fuse. This part protects other microwave components from power fluctuations, and causes a complete loss of power when it fails, meaning your microwave won't work. To access the ceramic fuse, located inside the cabinet near the power cord, first unplug your microwave. Use a multi-meter to test the continuity of the fuse. They look like this:
If the oven will not power up, but you are getting some display lights ... then it could be a thermal fuse in the back or a faulty door switch.
Helpful?
Good luck on your troubleshooting!
Mar 04, 2018 | Ovens
MIcrowave stopped working
there is a 15 or 20 amp fuse behind the control panel. turn power off at breaker, remove control pand the fuse will either be round and the size of a quarter, screwed in or will be about an inch long and cliped into place
Nov 19, 2007 | GE JTP85 Electric Double Oven
GE Wall Oven - No heat (broil or bake)
On appliances like this only the heating elements use 220 volts. things like the clock, fan, etc use 110 volts. That is why some things work and other do not. Start at the breaker, sometimes a double pole breaker will have 1 side tripped, but will look perfectly fine. switch the breaker all the way to off then re-set. If nothing changes follow the power to the appliance remove the panel and look for some fuses, check to see if any are blown. Also sometimes the microwave will have a separate power source even though its built in to the same appliance. So that's not always a good symptom to follow.
Nov 10, 2007 | Ovens
Jenn-Air JMW8330DAS Stainless Steel Electric Double Oven Logo
344 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
