Question about Compaq dc7100 Small Form Factor (PJ361UA) PC Desktop
No power Hi there! Its been 2 month I haven't turn on my computer but just now I turn it on it is not working at all no power and even the cpu fan is not spinning at all can anyone help me with this please thanks.
  • s4laman Aug 28, 2007
    Thanks for the help you are right mite be something wrong with the power power supply cause the cpu fan not spinning when the power switch on but anyway thanks for the help really appreciated. Thanks
    Problem Solver:
  • 20 Answers
1. Please check with the power supply of pc from a/c plug. 2. if power supply is ok then ensure that the input poewer cord is at right position in behind of cpu. 3. If you are using old type power supply (which do not autumatically turned off by operating system) then there is problem with power switch or SMPS. 4. If you are using advance power management (generally used in now-a days computers which is automatically turned off by O.S., then there may be a problem with power pin that is connecting thae mother board and power button. Shut down your computer and open the cpu chasis and tighten the pin and ensure that it is properly inserted (the location of the pin is near hard disk lid pin, power lid pin). 5. If this pin is ok then check with pconnecting wire of pin and power button and also the power button. 6.Then turn the computer on. If it does not work then check the power connectors from SMPS to mother board are properly installed and inserted. 7. If power connector is ok then there is posssiblity of problem with your SMPS (power supply) of computer. 8.Generally due to heavy load of power and long usage the condensers of smps get mailfunctioned. Take the smps or computer to a local hardware expert.
Posted on Aug 25, 2007
My NB temperature over heats really easy. What can I do to fix this?
Your computer is overheating. Three causes of overheating are:
1) Dust - Dust inside the computer, dust clogging the fans, dust clogging the vents, dust around the cpu and heat sink. Remedy - Open the case and blow out the dust with a can of compressed air.
2). A fan is not working. Remedy Replace the fan. There are two so find out which one is not working. One is inside the Power Supply where the power cord plugs in and the other one sits on top of the CPU and Heat Sink on the motherboard.
3) The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the unit cool. Remove the Fan, CPU and Heat Sink and apply a fresh coat of Thermal Paste.
May 07, 2012 | Gateway DX4300-03 Desktop PC
I have an HP Pavillion dv5-1125nr. I haven't
seems your cpu fan is damaged .
i suggested to contact an expert technician to repair the necessary damaged devices.
pay attention : don,t turn on your hp till refer to said technician.
good luck
Aug 28, 2011 | HP Computers & Internet
I seem to have a problem with the power to my computer. After 2 days of searching all kinds of forums I still haven't found a solution. The computer won't power up, no fans are spinning, not a...
First remove the power plug from the smps and press the power switch few time and wait for few minutes the re plug the power connector to the smps and switch on the computer if you still dont have power then you will have to check whether the smps work to test that its not enough to test the voltage in the 21/24 pin you will have to short the green wire and the black wire and see whether the smps fan is working if the fan is not working then the problem is with smps
Jul 30, 2011 | ASUS Computers & Internet
First of all, I have a Gateway Model FX7026 desktop computer. My daughter was using it when suddenly the monitor screen becomes black. She tried to turn the computer on again but nothings happen. I open...
check if the cpu fan its working fine, maybe is damaged o dirty, you clean up with an air compress can
if still doesnt works you can try to replace the fan and see if it works
Mar 31, 2011 | Gateway FX7026 PC Desktop
I recently moved, my computer tower was working fine before i moved it, and now it doesn't even turn on. i've tried different plugs and when i looked inside it, a green light is on, so it is apparently...
Do the fans inside the case spin?
If so, then the computer is getting power.
If you have an older computer, with a Pentium 2 or Pentium 3 CPU, it's possible that the "slot-mount" CPU has been dislodged from its "slot" socket. Turn the computer off. Disconnect the AC power.
Make sure that the CPU is properly "seated" into its socket.
Oct 04, 2010 | Computers & Internet
Dell dimension 4600c won't turn on since we had a power outage
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
try replacing the cpu fan or any additional fan the laptop.also the power socket may have carbon deposit.,clean it with hard scrub,but make sure all the systems disconnected form power source.
look for more details in shortly.
Mar 10, 2009 | Acer Computers & Internet
Asus p4vp-mx cpu fan turns nothing else works
Try to removed the memory and cleaned with pencil eraser the contacts and install it back.
Jul 13, 2008 | ASUS P4VP-MX Motherboard
My computer wont go to windows xp when started up and it doesnt even go to any type start up screen
hi gllwymiller;
1.check all your connections
2.check monitor and cpu power
3.when you power on your cpu, do you actually hear the fan turning or see your power led light up?
4. what OS are you using?
5. Feel the rear fan or your CPU, is it blowing out air?
get back to me :)
Jul 01, 2008 | Gateway Computers & Internet
Computer won't load anything
Possible RAM problem, also failing electrolytic capacitors in the power supply and/or motherboard can cause these problems.
Look for swollen/bulging/leaking electrolytic capacitors.
It might help if you mention make/model of the computer and the operating system you are using.
Jan 02, 2008 | Computers & Internet
Compaq dc7100 Small Form Factor (PJ361UA) PC Desktop Logo
67 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
