Hello
I have a samsung monitor 920B bought less of 2 yars ago, but unfornutalely I lost my bill, so no manufacturer garantee.
the problem happened yesterday, the screen came black but the power light is on.
the screen image was excellent, pixels , etc all ok
I ask myself if the price to repair this monitor is expensive and if it worth or not better to buy a new one
Thank you
Patrick
I think....
Your PC is overdriving the monitor and it is protecting itself from harm. Something changed.
Start
in SAFE mode (press F8 wile booting) and SAFE mode to see if it works
ok in DOS while booting and then in Windows DEFAULT setting. Then Reboot and readjust to something
sensible (1280*1600, 32bit, 60Hz)
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Goto mfg and DL and reinstall the correct drivers again
Good Luck!
Let me know if this fixes it
OK, do you HEAR any crackling High Voltage noise coming when you hit the ON button (Sounds like Hsssssssssssstt t t tt t) and then maybe it immediatly collapses?
I got it! Pull the plug and let it sit for 10 min, then put a Post-it note or small piece of paper with a bit of tape on the screen. it should 'hang' and move freely if you blow on it.
Watch the paper and Plug in the monitor - Anything happen?
Now, Watch the paper and Hit the Power button - anything happen?
Let me know
Sry - Improvising here ;-)
Neon, No
Fluorescent, yes. That or the inverter transformer/HV supply. YYou can get parts to fix yourself for ~$50.00
I looked up the wrong monitor, sry didn't think yours was a flatscreen LCD ;-) - My bad
thanks for your answeer but thhere are nothing on the screen.
the screen not show anything even on boot
so I can\t check in safe mode because I didn't see nothing
the power led is on, thats it
Hello
finally the problem is well inside.
I brought the monitor to a repair shop and they said this is the neon around the sceen
I don't really know about it but thats what they said
until then I had to buy a new screen. A Dell 24" HDMI.
this time I will keep my billing somewhere safe.
what you think about the neon. I never heard about this part.
and is it should be expensive to repair
The repairman called me today. they found the real problem
it is not the fluorescent, but simply the power supply as I tought first
the price to repair will be 100.00 US
since I don't have no shematics, I can't test the voltage.
so I told him to repair.
Thanks for your support
