Question about Siemens Gigaset 2420 Cordless Phone
Msg-blinks no display
My 2420 has been a fantastic phone for a couple years,recently the 'msg' lamp blinks rapidly (4-5 times/sec) and the display is completly blank.except for rythmic interferance to the handset the phone works otherwise. have read a lot of posts,but with no display or menu 'map' ive been unable to reset or clear this. can this be restored? it's posible this went through an elictrical storm with no protection on power or line any help here would be hot tnx D-Dan
  • 106 Answers
Hi Dan, Yes it is a very nice system, but like any device it is sensitive to electrical storms and power fluctuations. A surge or sag (AC power going up or down), can cause the sensitive digital chips to get damaged, and from my experience if you have tried resetting the unit, and your msg lites continue to flicker and the LCD is blank, it has some serious damage and needs repair or replacement.
Posted on Jan 11, 2008
I have a sony wega kdf-42a10 its only years old. i already replaced the bulb about a year when i turn it on the picture comes up then is there for about 4 to 5 sec. then disapears... they...
The tv also have a board that called a Ballast board this board only job are to ignite the tv lamp only.Hear alot of clinking too while the stanby light are blinking.Yes,the Ballast board it is dead and not help to ignite the lamp and helping it stay on.
Aug 25, 2011 | Sony KDF-E42A10 42 in. LCD Television
Sony lcd projection tv (kdf-60wf655) Tv lamp turns off after 30 secs then come back on over and over ,Green light is solid when lamp is on and blinks green when the lamp goes off. Only when I turn off the...
The board that call the Ballast board might dead,require replacing.This Ballast board only job are to ignite the tv projection lamp.The tv projection lamp been inside the tv like 1 1/2 or 2 years already?Yes.Tv used it everyday like 4 or 5 hrs daily?Yes,the tv should be replacing it projection lamp too.Tv projection lamp life are ending too.
Jun 10, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
My sony sxrd 60 comes on only for a sec than go off and red stanby lamp blinks 4 times,i have cleanned vents and checked bulb door,can only turn tv off and back on ,and still onlly get screen to show...
4 times red light blinking indicates problem with exhaust fan that is not running and tv shuts down instantly due to protection mode activation.
Please check exhaust fan and make sure its connector is plugged in and fan runs freely.
Apr 19, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
The Control Panel/Dispenser light went crazy...
Sounds like a electronics problem would need to replace the board, LG parts are not normally expensive.
Apr 11, 2010 | LG LFX25960ST Stainless Steel French Door...
Sony wega kdm42we655 replaced burnt out lamp , power up for 30 sec and turns off, the red light blinks 3 or 4 times then goes off for 10 sec and blinks again
there is still problems in your power supply board. check it again. further no lamp is needed to be changed.
Apr 23, 2009 | Televison & Video
Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 31, 2009 | Panasonic PT-44LCX65 Television
Display shows "1 new/1 saved" yet mailbox empty.
The message left on your phone was probably left by someone internal, meaning they called your phone and when you did not answer, they hit their message key which turns on your message lamp and display. If you press your message key and it rings someone in the office then they are the one that left the message and they have to answer your call. You can usually cancel the lamp/message on your phone by pressing " Intercom ( your extension button ) " # 4 0 9 and then hang up. You can have up to four ( 4 ) messages on the phone so it may take putting in the code a couple of times to clear the display.
Jul 24, 2008 | Toshiba DKT-2010 Corded Phone
Message Light
Press " Intercom " # 4 0 9 to cancel msg lamp that was not left by voicemail or press the message lamp and when it rings to an internal phone have someone answer it and that will turn off the lamp also.
Jun 12, 2008 | Toshiba DKT-2010 Corded Phone
PT-45LC12 Problem after startup
When the lamp flashes 4 times this is what the error code means IC 2301 pin 11 has detected an LCD error which is caused by an error in the LCD power CBA. which means the lamp voltage has become more than 130 volts or less than 30 volts. Or the lamp current is more than 5 amps, or the lamp is cracked. Its one of thos 3 reasons that will make the lamp indicator blink 4 times. Hope this helps. If you need the service manual for this model you can get one emailed to you from the following link.
Mar 31, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Siemens Gigaset 2420 Cordless Phone Logo
419 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
