Every time I turn the TV on with remote it fails to remember channels and displays no signal. If I scan it finds channels and works fine until turned off and next turned on with remote.
The fault has become intermittant. I am looking for a pattern, remote VS button Vs off/on sw. Thanks for assistance. I will look into thisThe fault has become intermittant. I am looking for a pattern, remote VS button Vs off/on sw. Thanks for assistance. I will look into this
hello i have a brook scren of my ACer Tv so I'd like to know who have a Screen to sell me call me 514-660-2312 hello i have a brook scren of my ACer Tv so I'd like to know who have a Screen to sell me call me 514-660-2312
AnonymousMar 13, 2014
tv fails to save channel scans when I turn off tvtv fails to save channel scans when I turn off tv
AnonymousMar 23, 2014
my videocon 32" lcd tv is having a problem that when once the tv is on the switching pannel as well as remote stops working.if in case it works the tv hangs up while changing channel otherwise it works for unlimited time untill we change channel.my videocon 32" lcd tv is having a problem that when once the tv is on the switching pannel as well as remote stops working.if in case it works the tv hangs up while changing channel otherwise it works for unlimited time untill we change channel.
You can't post conmments that contain an email address.
I had that problem, I sent it to repair, because it was on warranty, they told me that they had to flash its BIOS again, so, that is a software problem. That was in my case, I hope can help you. Sorry for my english.
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
looks like the same problem i have with my 32" acer tv, it seems to be a problem of acer TVs get someone to check the capacitors in the power supply.... I think one might be bad.
Acer AL2671W 26in problems: (1) sometimes sound but no picture, (2) or screen freezes pink etc. (3) or remote won't turn it on/off (4) or it gives up and says "no signal". Turning it off/on usually solves it temporarily.
I have run into the same problem with a different model (32 inch from Circuit City). You may have found that there is almost no support from the co or web. I do not have an official solution but have some work arounds that have done the job for me. WA#1 = after a channel scan tune to a HD/digital channel before you turn the set off. You need to do this each time for several times, because the set when turned on to a regular cable or analog station will default to skip all channels. After several times the set should remember your channels. WA#2 = after a channel scan, go to the skip channel section of the menu, and if your remote has the colored buttons on the bottom scroll through the channels using the red and green (up and down on this menu) buttons. This apparently helps the set remember not to skip your scanned channels. These are not glamorous solutions but appear to trick the TV into not re-setting the skip function for the channels. Best of luck.
I have the same problem - has anybody a solution?
i have the same prolem.!!! i live in holland
Hi All,
same problem (same brand and model) since about Xmas 2007.
Every time I scan TV freqs and put channels in memory, they survive less than a day, then I've to rescan again.
Acer's Warranty expired, of course.
Anybody can help me?
Thanks in advance
Enrico Fassini
