Question about Fedders A6X05F2D Air Conditioner
FAN ISNT TURNING ?
Hello,, I have a fedders window unit, Series 6X07F2B i cant find tech info any where . the compressor turns on when i power on the unit but the fan does not turn , no nothing as well no cool air , and keeps turning off is there any info online onwhat is wrong ? or how to take front off and inspect inside ? Thanks in advance Mir*
  • FRISKYMIR Aug 25, 2007
    thanks for the help ,, but what could make the fan stop running just like that ?
  • Anonymous Jul 07, 2008
    fan does not turn . how do i disassemble
  • 625 Answers
You won't see much when you take the front off just the evaporator coil and air output ducting. You'll need to remove the whole back cover to get at the workings. The evaporator and condenser fan are one motor with a double shaft. the double shafted motor may have dry bearings - they are oil-lite bearings, sintered bronze set in a felt holder. there may be a small capacitor on the outside of the motor. with the back cover off, locate the wires going to the motor. if you have a meter to read voltage, proceed. If you have no meter STOP, visual inspections won't get you very far. the motor probably is a multispeed motor. If you are squeemish about taking voltage measurements don't go any further. Get someone with knowledge of electricity.
Posted on Aug 25, 2007
  • THOMAS MIERZWA
    THOMAS MIERZWA Aug 26, 2007
    dry bearings I would say. they keep going and going then all of a sudden stop. I have a 5000 btu window unit that I haven't taken apart yet and its still working but next spring I will take it apart just to clean out the bugs etc.
SOURCE:
Fedder Heat Pump not Running
you can check your heat pump on the outside by turning off the power and listening to see if it makes a whoosh sound. and then turn it back on you should hear it kick in. Is the outside unit running? Sounds like an electrical problem maybe in the breaker or the contactor on the inside of the unit. This is where the 24 volts from the thermostat call to the 240 volts to kick on the condenser fan and compressor. Be real careful in messing with this because of the high voltage.
Jul 09, 2010 | Fedders C36ACD1VF Split System Air...
Unit turns on,compressor kicks on but fan does not turn,motor makes humming noise
sounds like fan motor has gone bad or the capacitor to fan motor is bad...open up unit ,see if motor is frozen..does it turn freely..if so ,replace capacitor,or fan motor is bad...
Jun 09, 2010 | Fedders AED24E7F Wall/Window Air...
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
Fedders A3X06F2G window air conditioner fan does not spin
Fan motor is stuck or defective it might need replacement. Check for broken fan blades or obstruction.
Aug 24, 2008 | Fedders A6Q10F2B Q Chassis Room Air...
FEDDERS D CHASSIS A6D24E7A
Oh, the compressor motor's borked or overworked and overheating, or its capacitor failed short (perhaps the motor is shutting off from thermal shutdown...but you get to find out whether that's so. Be safe.) Alternately the temperature sensors have gone touchy on you. Once you gently vacuum it clean, try keeping incandecent bulbs in series with the compressor to get an idea of how loaded that thing is as it runs for those 5 minutes or so; the load might change more than you expect, just pay attention.
Hopefully you won't have to replace the compressor or motor; but it's doable if you're a certified technician with like equipment (so you can handle the refrigerant decently.) Most shops will streamline a bunch of similar jobs together to cut the waste and setup time.
Bigger conditioners are so much more efficient than little ones...syndicate the A/C?
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Compressor runs even when turned off
You could have a relay stuck closed, so every time the power is on it feeds electricity to the compressor.
Mar 10, 2008 | Fedders AEY08F2FCOM Wall/Window Air...
FAN NOT WORKING*
If the fan will no run at all iit may have a capacitor bad, swelling around the top, or you may just need to replace the motor.
Aug 25, 2007 | Fedders A6X05F2D Air Conditioner
Fedders Window AC Unit
I would try to start the unit with only the fan running at first. If it stays running then cycle on the compressor and see how it does. If the unit does not operate when compressor is turne on then we have to dig deeper into that.
Aug 13, 2007 | Fedders J Chassis A6J12E7A Air Conditioner
Fedders A6X05F2D Air Conditioner Logo
137 people viewed this question
Top Fedders Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Ekse
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
