Question about Motorola Walkie Talkie 2-Way Radio
Operation of handie talkie GP338
Sir, I m having Mototorola Handie talkie GP338,i want to know more operations like saving phone memory,making a call,sending messege,and use of Radio etc.Please give me proper solution
  • 123 Answers
Mostly of this features need to be able by the programing software, this mean that if you dont find it with your menu botton, mean that the radio has disable this features, also depends on the system that provide the service to have this features working, on your profile as customer, ETC Check this link can help you http://www.motorola.com/governmentandenterprise/id_2011i/en-sg/public/functions/browseproduct/productdetailpage.aspx?navigationpath=id_801i/id_1388i/id_1152i/id_188i/id_1363i
Posted on Aug 27, 2007
SOURCE:
I have 2 VISAR HANDIE-TALKIE FM RADIOS MODEL: HD5RDD9AA4AN + DON'T KNOW HOW TO PROGRAM THEM TO THE SAME CHANNELS
This is a discontinued radio from Motorola. programming requires a cable to connect to a computer, there is no direct programming available.
While this is not really an answer, the programming software is specific to Motorola and you need to buy both the software and the cables from Motorola.
you would be better served, to determine what frequencies you want and then pay a certified Motorola dealer who has the software to do the work for you.
Dec 05, 2016 | Radio Communications
Do you know the frequency range of the Motorola Handie Talkie Tanapa PMUD1673C?
As a general rule handheld radios will talk up to 2 miles line-of-sight. Anything you place between the two radios will reduce range. Talking from inside a building to outside, you can expect 1/4 to 1/2 mile. This being said, a radio can talk as far as it can see, so if you were on a mountain top, you could conceivably talk many miles into a valley below. Height and placement of your antenna determines range. Holding your antenna upright perpendicular to the earth will give you the best range.
Nov 30, 2016 | Motorola Radio Communications
I am looking for an owners manual for motorola gp68 handie talkie radio
You may download the manual from here: http://www.repeater-builder.com/motorola/gp68/pdfs/gp68-um.pdf
Jan 19, 2015 | Motorola Radio Communications
How to get it to scan handie talkie ltma model
One of your buttons would need to be programmed to Scan. This is done using Motorola proprietary software, a cable, and a radio interface box (RIB). Your local dealer should be able to assist you with programming.
More info at http://n1su.com/900.html
Best regards.
Aug 30, 2014 | Radio Communications
Hi, Was given a Motorola Handie-Talkie Tanpapa: PMUD1481A Model: AAH25KDH9AA6ANFD In good working order, BUT I need an owners manuel to reset and operate. HELP! Thanx, Bob
The radio you are describing is a HT1250 VHF 5 watt with display and full keypad. This radio cannot be reset by the user. It is a dealer programmable radio requiring a RIB (radio interface box), cable, and Motorola proprietary software. Your local Motorola dealer should have a subscription to this software and be able to program the radio to your frequencies.
Here is a link to the manual: http://www.connectingyou.com/media/HT1250.pdf
Best regards.
May 21, 2010 | Motorola T6510 XLR Talkabout Two-Way...
Operation failed when receiving a file via bluetooth
don't worry. just make a backup of your personal data such as songs, images, games that are in the memory card. save that backup in your pc or if a have required space in your cell so save that backup there. now formate your memory card. after that replace all your data and then try receiving again. it will work, for sure.
Aug 09, 2009 | Nokia 6300 Cellular Phone
Music Player: Not enough memory to perform operation delete some data first
nthing to worry change ur message setting ,put memory card memory as memory in use. after cahnging tht u cn easily save ur files to ur memory card
Feb 19, 2008 | Nokia N70 Cellular Phone
Saving problem
Go to message setting and Change the memory in use to memory card instead of Phone
in your phone it is using phone memory for incoming messages ,. THatis the Problem,
Jan 21, 2008 | Nokia N72 Cellular Phone
Radio Communications Logo
283 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
