Question about Toshiba Satellite A105-S4074 Notebook
Audio Troubles All audio plays choppy and is often slowed down. I have tried installing the appropriate audio drivers, but the problem persists. My computer is installed with Realtek High Definition Audio.
  • 1 more comment
  • kdw536 Aug 25, 2007
    there doesn't seem to be any kind of environment configuration. i also tried uninstalling the device and having windows reinstall, but the problem was still there. in device manager there is a listing for legacy audio drivers, as well as realtek high definition audio. does this have anything to do with the conflict? there doesn't seem to be a way to uninstall the legacy drivers, but could i somehow install different drivers in their place?
    thanks for the help...
  • mushupork Nov 07, 2007
    i have an acer aspire 9210 and had the same problem with my audio. it used to work fine now it is all choppy and wrong speed etc. i removed the driver from device manager and downloaded a driver from realtek. but still the same problem.
  • the hawk425 Mar 15, 2009
    i have same problem and i think i have same computer its aspire its lke a small laptop when i first bought worked fine my sister has one working fine but mines not working but like somtimes it will for like 10 mins tops this it just either goes really slow or like skips reallly fast ive updated driver rolled back reinstalled also happens with any speakers
I had the exact same problem with a friend's Toshiba Satellite A105-S4014. XP had failsafed to PIO mode for both IDE channels. I'm not sure what caused this to happen, but after a general clearout I uninstalled both IDE channels then rebooted to force reinstall and everything is now hunky dory.
More info here http://www.onthegosoft.com/dma_setting_nt.htm
Posted on Jan 06, 2008
    President:
  • 2,961 Answers
There must be a driver conflict if this is what is happening when you play music from your hard drive, if your playing from a cd make sure it's not an encrypted music file. Go to my computer icon, right click>properties>hardwrae tab>device manager, then go down the list to sound, video and game controllers, click the '+' sign, highlight realtek and then right click and select uninstal. Restart the system and the audio will automatically re install and use the appropriate driver, you should now have normal sound.
Posted on Aug 25, 2007
    Problem Solver:
  • 17 Answers
This must be a problem with the configuration utility. In some cases when using realtek or c-media or related products that come with a utility to help you change the environment, some environments may make you sound to be choppy. This may also be memory or processors speed that may not support that kind of configuration. Try opening the utility usually at the bottom right coner of the screen at the taskbar and try changing the environements.
SOURCE:
Computer
Choppy Video? What do you mean choppy video? Is the video starting and stopping rather than playing continuous? If so, either you need more memory or the site you are watching the video from is slow. Also sometimes you line speed on the computer might be slow if you are watching the video online.
How does the video play if you played a DvD in your computer? If it plays the DvD without stalling, then your problem is more than like the site you are watching or the line speed as you stream the video.
Mar 29, 2012 | Computers & Internet
The speakers sound choppy and slowed down so the sound is heavy slow...like chopped and screwed basically.. there hasnt been any damage to it either.
Try installing the latest audio drivers.
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Mar 25, 2011 | ASUS Eee 4G Notebook
When ever I play video and sound files, or run computer games, even computer booting up, the audio is laggy and choppy with lots of static, and video playback is accompanying it by being choppy and laggy. ...
I would reinstall the sound driver by going to the control panel choose system then when the device manager tab comes up choose hardware.Find the sound devices then right click on it to remove it.Windows will autimatically re-install the device.
Mar 08, 2011 | HP Pavilion G61336NR Notebook
No sound , sound drivers are working
Most common reasons for this trouble are:
  • Such kind of troubles arise after some device / software is installed which tries to gain control as default sound device.
  • Also while un-installation of certain softwares, some shared files are removed. At times some important shared file can be deleted which causes troubles with working of sound drivers.
  • While installing certain games, it tries to gain control of sound or video drivers and may accidentally harm these driver softwares.
Lets see the ways to fix such troubles
Step1 : First of all check what is your default audio device setting. For this, open Control Panel > Sounds and audio devices, open Audio tab as shown in picture below.
See that the Device selected is your sound-card or on-board audio device. It should not be blank or some modem device. Set the Default sound playback and sound recording device correctly from the drop down menu. If your device is not there in this list see the step 2.
Step2: If the step 1 is not successful, it means that your sound device driver software has become either corrupt or has been accidentally un-installed. In such case, install the sound driver from the sound-card/mother-board driver CD. You can also download the latest driver if you don’t have the driver CD. After you install the driver, restart your computer, and then check the settings as in step 1 again
Jun 01, 2010 | Microsoft Windows XP Home Edition
My audio is not working on my sony vaio labtop vgn-a690???
go to device manager check in the drop drown box next to your audio controller see if any yellow question or quototation marks appear.if so you need to replace our driver.
Sep 22, 2009 | Sony VAIO VGN-A690 Notebook
Audio Troubles
hi!!!!
there was a corrupted file in your windows registry or in windows system 32
the solution for that is to reformat your operating system
back up all your important files!
Sep 18, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Audio running choppy
uninstall the audio driver and re-install it. it will work fine
Jul 19, 2008 | HP Compaq Presario V2000 Notebook
All my videos dvd and online play choppy and slow Help!!!!!
check and see if DMA is on.
http://www.real-knowledge.com/dma.htm
Dec 26, 2007 | Dell Latitude D800 Notebook
Toshiba Satellite A105-S4074 Notebook Logo
199 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
