Question about Archos 604 WiFi Digital Media Player
Wep key when i try to put in my wep key the keyboard only has letters a-f and numbers 1-9 and 0 how do i put my wep key in if the correct letters arent there
  • 2,985 Answers
Re: wep key
Does the manual not cover this function? It must be an alpha numeric combination function - similar to using Ctrl or Alt on a PC
Posted on Aug 25, 2007
0 characters
3 Points
Letters missing when typing acer laptop
To determine if the keyboard controller is faulty or the keyboard is faulty, connect an USB keyboard to your laptop. If all the keys work on the USB keyboard then the laptop keyboard is faulty and it needs to be replaced.
A replacement keyboard maybe available from this WEB site.
Keyboard replacement, LCD screens for mobile phones, Ipods and computer equipment.
Sep 02, 2012 | Acer Aspire One TAG 2 Tone Nylon Travel...
Why won't my wep key work?
it must be typed in exactly as you see it on the sticker on the router.....small case & upper case letters where the shift key to get capital letters on your i-pod's keyboard
Sep 10, 2011 | Apple iPod touch Second Gen (8 GB,...
My ipod touch can not connect to my netgear wifi
The most important things to remember when doing this is that to connect any device for the first time the router needs to be in pairing mode, and also the WEP key is case sensitive, when entering the key details, although the keyboard on the Touch may look like it is in caps mode it isn't, you either have to go into the keyboard settings in the control panel and enable caps lock or actually hit key cap before every letter in the key, or it wont connect.
It does take a degree of patience to do this but if you are very careful when doing so it works first time!
Jun 06, 2010 | Apple iPod touch
My archos 605 gen 5 cannot connect to internect
Try:- Menu Settings Language and Region WiFi Region.....set to "EUROPE" Followed by: Menu WiFi Status WIFi ...important that pasword format corresponds to that of your WiFI system eg WEP or WPA. The type of format will dictate the length of code. Generally WPA can accept a longer code than WEP format although a short code can be used for either. If your Archos is set to WEP and your WiFi network set to WPA (or vice versa) the format conflict will not allow the correct password to recognised It should be possible to use the
Dec 30, 2009 | Archos 605 WiFi Digital Media Player
Can not connect to the internet with my new itouch. Have tried all the resets. My password (which is correct) does not seem to work. Says unable to join network. The network is working fine with 2 other...
What kind of wireless password do you have? WEP or WPA? This makes a difference as Apple devices use a different algorithm with the WEP encryption that the rest of the world. If WEP, put a '#' in front and use the hexadecimal version of the password.
-=/ MLF /=-
Oct 20, 2009 | Apple iPod touch
Connect connect my archos 605 with WEP address!!!
i have a 20 to 30 digit wep key and i just changed the settings to 128 bit and made it a hexadecimal wep. (hexa- ?) it should work.
May 19, 2009 | Archos 605 WiFi Digital Media Player
Cant connect to net in other loc
i sort of have the same problem. at my house my linksyys always asks for a passcode. the passcode is either the wep key or the wpa key. look around the web to see if you can find where to find the wep or wpa key cuz i still havent found mine
Jan 25, 2009 | Apple iPod touch
Cannot connect to network with WEP key encryption
It will not connect to a wireless network with WEP. it supports only the latest encryption. Try changing the encreption on your router to WPA or WPA2
Mar 17, 2008 | Archos 605 Digital Media Player
Connecting ipod touch
Press pairing 1 button on the back of the livebox and then type in security code make sure that you type in each character in capital letters as the code it is case sensitive (don't set caps lock) for each character use the shift key - You will now be connected to the livebox.
Jan 15, 2008 | MP3 & Digital Media Players
Archos 704 WPA/WEP
The WEP or WPA is the password to get onto the network. Think of the router as the doorman. The printer needs to get into the club so it needs the password otherwise it can't get access.
The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with your router to see how to access this information. Some routers provide more than one WEP key. Use the first WEP key if this is the case.
Dec 02, 2007 | Archos 604 Digital Media Player
Archos 604 WiFi Digital Media Player Logo
44 people viewed this question
Top Archos MP3 & Digital Media Players Experts
 Mike M
Mike M
George Hoggarth
Level 1 Expert
Are you an Archos MP3 and Digital Media Player Expert? Answer questions, earn points and help others
