Question about Garmin zumo 550 GPS Receiver
No power in any way
Tried new Battery . Recharging,Motorcycle mount, and car mount. still no power
  • 1 more comment
  • Anonymous Nov 03, 2007
    Unit was on when I plugged it into the cradle on my bike. I powered it down, an dnow it won't come back to life!
  • Anonymous Nov 25, 2007
    Power supply on the motorcycle mount seems to be suspect. When checking the voltage on the "pins" reading varies between 8v to 9v. (Cable input reads 12v)
    Whilst riding the mount will suddenly lose power, resulting in going over on battery power, if seen in time, otherwise in just powers down
  • Roger Whipple Apr 20, 2009
    After the pins on my 550 zumo motorcycle mount got wet (from washing) the power became intermittent and then non existent. I see green corrosion around the pins from electrical activity. I only measure about 1 VDC on one of the pins. Taking the unit apart reveals significant electronics on a PCB inside the mount but no obvious signs of any water or overload damage. The zumo connector with gold-plated spring loaded pins is not accessible. The connector is bonded in place with a fragile flex cable coming out of it. The PCB would be replacable if you can get one, but removing the connector looks like it would destroy both it and the sealed housing.
    There are voltage regulators and other chips on the PCB and it may be possible to repair if documentation were available. Has anyone tried to troubleshoot this any deeper?
I had same problem. It seems like battery is dead. The unit just died and need to take battery out to reset. Finally, I figure it out that -- it's because the my Zumo550 is running out of memory!
I had a very low free memory available, then after it logs your trip for a while and used up all those free memory - it freeze...
Solutions >>> connect to your computer via usb cable. Try to free up some memory...
Posted on Dec 30, 2007
Guest, posted on Nov 25, 2007 - Similar finding
I suspect that the original power cable for motorcycle assembly is resistive. I have made a second cable (non-resistive) and the equipment turned off as soon as I connect it.
The internal battery is 4.2 V.
Posted on Dec 17, 2007
I charged it for about an hour on the bus connector (wall outlet did not appear to generate any charge). I then opened up the back and removed the battery. Put the battery back in; see if it starts. If so, turn off immiediately and continue to charge it to a full charge (at least 12 hours).
I found other users who experienced the same problem when their battery drained down to a very low level. The unit goes zombie and needs both a charge AND full reset (battery removal) before it can be resurrected.
Posted on Nov 16, 2007
SOURCE:
I put a new battery and plug in my Sym orbit 125 before I put it in storage for six months, tried to start it nothing happens it is totally dead...
Hi, Ian batteries go dead if not charged periodically, put your battery on a trickle charger or battery tender for 24 hours and you will be fine. For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Scooter or Motorcycle Battery Maintenance Tips
Recharging Scooter Battery How To
https://scootergrisen.dk/scooterhjemmeside/download/sym_orbit_servicemanual.pdf
SYM Sanyang Scooter Parts Racing Planet USA
http://www.sym-global.com/uploadfile/download/20140311030340.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 19, 2016 | Sym Motorcycles
I tried recharging my PSP but suddenly the power light which is recharging color (orange) suddenly shuts off, it's my first time since I just bought one.
sometimes people get thier chargers or batteries mixed up with other peoples, by swapping or trading, if that is u trade back, but it you have had no trade or exchange of chargers, or batteries, then i would suggest going to bestbuy, or anyother electronics store and ask a tech, or simply buy a new charger and if you have no results, new battery
Jul 14, 2011 | Sony PlayStation Portable (PSP) Console
My son was driving vitara he said it seemed to lose power as he was going until it stalled. he said the oil shows good on the stick, and it didn't over heat but won't start. ignition just clicks like a...
it is either going to need a new starter or your alternator is dead. also, have you tried recharging the battery? your battery may actually be dead. also, check your transmission fluid levels/color
Mar 28, 2011 | 1999 Suzuki Vitara
The battery is dead. We have tried recharging to
There is a hold down at the bottom near the battery,a 8 mm bolt head,or maybe a 10mm.
Mar 13, 2010 | 2004 Ford Crown Victoria
Iphone is not powering-on. Tried recharging.
Have you charged your battery for 24 hrs if not done so do it now. Measure the output of the battery if the battery output is ok then check the connection on phone where battery is connected and scrap a bit with screw driver. it might possibly have some sort of plastic quoting check both the battery and mobile points for any such quotings.
Jun 15, 2009 | Apple iPhone Smartphone
Can not fully charge new battery for my Acer3610 notebook.
Your battery is possibly broken.
If its in guaranty just ask for reair.
it can't be from ur treatment(unless u tryed to jailbrake it).
Apr 01, 2009 | Acer Aspire 3610 Notebook
Recharging
Had the same problem with mine. Strip your ipod and you'll find that the left hand end of the battery has been rubbing against the mounting screw for the hold button and the positive track is exposed causing it to short out the battery. Placing a piece of plastic between the battery and the mounting screw sorts out the problem. My ipod charged and the battery still works fine. It seems to be a common problem with this model. If you want more details email me at [email protected]
Sep 16, 2008 | Apple iPod classic MP3 Player
Battery not recharging
All batteries die sooner or later. I believe you have a dead cell.
1) Find another machine that uses the same battery and try it or
2) try another battery or
3) Give up and buy a new battery.
Good luck.
Apr 30, 2008 | Toshiba Satellite M35X-S111 Notebook
Garmin zumo 550 GPS Receiver Logo
451 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
