Question about LG KG800 Cellular Phone
Assign photos right, my phone is really taking the p. i've been trying to assign photos to people that ring me. i've tried reading the manual; no help there. anybody got an KG800 and know how to do that?
  • 69 Answers
You go on to camera,not where it says album but the little icon thing on the left click on that, then select across once and it will come up saying size you have to change the size to 72x72 for a contact photo then take the photo, then go back onto the contact you want and the picture will come up hope you get it: you need to take the pictures in the smallest resolution in order to be able to add them to your contacts
Posted on Aug 25, 2007
How to add a photo to the contacts ?
you can't add a photo which you have sent through Bluetooth as it is stored in a emulated environment. try to move the photo first on your images folder or whichever folder you want thereby removing it from the emulated environment. then go to contacts, tap menu, tap the contact you want to edit, tap the image, tap assign or replace, then locate the images you move and assigned it.
else you can also try the work around.
locate the folder where you stored the transferred photo, tap the image, tap menu, tap set as, there are some options asking you what you want to do, set as wallpaper, etc and one of them is set as contact photo, tap set as contact photo, locate the contact whom you want to assign the image and then tap save.
hope this helps.. :)
Jun 19, 2015 | Samsung GT-S5300 Galaxy Pocket
LAN Network, both PC's with static IP's and defaullt and DNS addresses are 192.1683.1.1 tried the other defaults. Both machines connected. when i ping each others IP's request timed out. please help
Can not really understand what exactly you have done. Please try the following steps:
1. Assign static IP on pc 1 as 192.168.1.2 assign subnet mask as 255.255.255.0. 2. No need to assign default gateway and DNS. 3. Assign static IP on pc 2 as 192.168.1.3 assign subnet mask as 255.255.255.0. 4. No need to assign default gateway and DNS.
Open dos and try to ping. In case if the ping fails then disable all the firewall on both the pc's and try again.
If you are running windows vista then in network and sharing center make sure network discovery and file sharing is enabled.
Regards,
Rashish
Aug 06, 2010 | Accton CheetaHub Classic 2040 Networking...
Ringing volume
sound problem or volume right?,,,check the sound device or speaker of your mobile.. if the volume is active try to change it
Jun 26, 2010 | HTC Touch Cellular Phone
Assigning ring tones
hii
Inorder to assign a ringer id on Moto phones, Plz goto to contact of a particular person u want to assign thru phone book, U will find a an option RInger ID.
Note: This option shows up only if the contacts are saved in phone memory.
You can always refer ur phone manual. (if u dont have a manual then, you can download the eManual for phone)
Regards
Sep 06, 2009 | Motorola Mobility PEBL U6 Cellular Phone
Automated Attendant not on everyone line
The below texts should help you.
**Found on page 9-8 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
Use Line Assignment (#301) to assign all the lines that you want the auto attendant to cover
to extension X.
**Found on page 4-47 of "Partner R6 Install and Upgrade Manual" so your system may vary slightly:
To assign lines to a specific extension:
1. Press [Feature] [0] [0] [System Program] [System Program] [#] [3] [0] [1] at extension 10 or 11.
2. Enter the extension number to be programmed. For example, to program extension 15, press [1] [5]. The red light next to each button that has a line assigned is on steady; the red light next
to each button that has a pool assigned flashes.
3. To remove all existing line assignments, press [Remove] before selecting a line.
4. Enter the line number to be assigned. For example, to select line 1, press [0] [1].
5. Do one of the following:
■ If you want to assign the line to the first available button with lights, press [Next Data] until the
display reads:
Line Assignment 15 L01
1 Assigned
1 Assigned is the factory setting.
■ If you want to remove a line assignment, press [Next Data] until a display like the following
appears:
2 Not Assigned
■ If you want to assign the line to a specific button, press 3. A display like the following
appears:
3 Select a Button
Then press a button with lights to assign the line to that button. If you use option 3 after a
line already has been assigned, the line moves from the old button to the new button you
select.
6. Do one of the following:
■ To program another line for this extension, press [Next Item] or [Prev Item] until the line number
appears on the display. Then repeat Step 5.
■ To program another extension, press N P and begin at Step 2.
7. Select another procedure, or exit programming mode.
Feb 05, 2009 | Avaya Corded Phone avaparp18d
Nokia 6500 wont hold ring tone
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from other phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 17, 2008 | Cell Phones
My phone is not ringing on incoming calls
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
Different ring tones for different Contacts
I don't know how you can assign pics/music to sim contacts - I tried but I couldn't work it out as well. When I click 'edit' on a sim stored contact a menu appears with memory, name and number only.
However, if you move your contacts from sim to phone, you will be able to assign both pictures and ringtones. This time the edit menu extends to home, mobile and office number, e-mail, group, ringtone and photo (with photos make sure size is 680x480 or smaller).
Dec 10, 2007 | LG Prada KE850 Cellular Phone
Unable to assign photos
Here is the MAGIC NUMBER. Make sure all your jpegs are saved sized: -
640 x 480
The phone CANNOT ADAPT any other image size to the caller contacts list!
Oct 26, 2007 | LG Prada KE850 Cellular Phone
Phone wont stop ringing
this sounds like a short circuit inside the devise. Have a repair specialist check it with the proper tools.
May 15, 2007 | AT&T E5908 Phone
LG KG800 Cellular Phone Logo
56 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
