Question about Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark 1185 - paper feed problem
Hi - our all in one will not feed the paper o\properly - seems to be grabbing the right edge more and pulling it in squew (which obviously causes a jam). My husband has had a look at it and we both can't figure it out - any suggestions
    Sergeant:
  • 390 Answers
You may be missing a very small jam. Use a torch and tweezers, check down the back, also open cover, check even where you think paper wouldn't jam. Especially in teeth, rollers. Look for foreign debris as well as paper. Also, turn off, unlplug all cables/usb etc and replug, turn on. Finally, never load more than about 20 fine sheets at a time, reset printer settings to default. As a last resort, try uninstalling and reinstalling the printer.
Posted on Aug 25, 2007
SOURCE:
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Hi, My Lexmark 2350 is not feeding paper through. It pulls on the right hand side but doesn't feed through and then says there's not paper in the tray. Any suggestions? Karla
Try to remove the sheets of paper from the feeder. Grab a flashlight and take a look into the feeder for any foreign objects that might have accidentally fallen into it. If none, unplug and replug your printer into your power source to reset it. If problem continues, please contact Lexmark technical support for additional assistance. Thanks.
Mar 06, 2011 | Lexmark X2350 All-In-One InkJet Printer
Hi, i have a lexmark x4550. The pick up roller (the roller that grabs the paper and feeds it into the printer to get printed on), is not working, at least one of them isnt (there are two i think,,, but on...
Try the following: take an A4 sheet of paper and glue a 2 - inch strip of sanding paper onto the top of the sheet (full width of the page). sanding paper should be about 120 grain.
Now feed the page with the sand paper first (rough surface on top) into the paper inlet. grab and hold the paper, then press paper feed or send a print job. The printer tries to feed you special sheet, but you won't let go. This will sand off the gunk from you feed rollers and give a bit of rough surface to the rubber. Repeat if needed, it should cure the problem.
This works if the problem is the roller surface, it will not fix a problem with misalignment or a missing/broken spring in the feed roller mechanism.
regards, the perfessa
Aug 23, 2009 | Lexmark X4550 Multifunction Wireless Color...
Riso GR3770 will not pull the paper through once it passes the initial feed assembly. The paper ''picks up'' just fine, but after the lead edge enters the machine, it kicks off impression and gives a...
what happens sometimes is the rear side of the registration (shiny silver color) roller becomes worn down so bad that the spring cannot grab properly. the registration roller, in this case, would have to be replaced.
the way to check is by getting to the back of the machine, and if this is the cause, the spring should be a little wobbly on the shaft. with a new roller, the spring fits snug, and grabs properly for it to feed.
Mar 31, 2009 | Riso Office Equipment & Supplies
Lexmark e250dn
Over time the rollers get slick and hard. If one side is slick and the other edge is not, it will grab paper sideways and you get a paper jam. Get some rubbing alcohol and rub the rollers (completely all around) to get some debris removed. Some rollers require a slight rubbing with an abrasive pad.
Feb 18, 2018 | Lexmark E250dn Laser Printer
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Machine not feeding paper through
try cleaning the rubber rollers with a damp cloth and make sure there clean. also check to see if the paper is making contact with paper.
if that fails check the leading edge of the paper for damage incase something maybe blocking paper.
May 07, 2008 | Canon FaxPhone B95 Plain Paper Inkjet
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Lexmark JetPrinter X1185 All-In-One InkJet Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
