Question about LG WM-2277HW Front Load Washer
Lg wm2277hw Had washer for amlost 2 yrs. OE messgae coming up. Washer will not drain. Checked hoses and filters. Does not work. LG nothing but problems. Please help!
  • 1,543 Answers
You do not have an "OE" error, you have a "DE" error. DE error is "drain error" which displays if the washer has not pumped out after 10 minutes. If there is water in the machine and no obstruction in the filter I would suspect that the pump impeller is bad, and you would need a new pump motor. (part # 4681EA2001D) Pump motor is located directly to the left of the filter, and can be accessed by tilting the washer back and reaching it from underneath. The pump housing is held onto the machine by three phillips head screws.
If you have "DE" error and there is no water in the machine that's a whole different problem I'll address if you say that's the case.
If you need good service, try calling a small dealer who sells and services the procuct line you are having a problem with. You can find LG servicers at us.lgservice.com but avoid the utility companies, A & E, Sears, and all the big guys who try to service every brand but often times are not very familiar with your brand.
That should help. Carl S., factory authorized LG technician for over 10 years.
Posted on Aug 26, 2008
  • smcrey1963 Sep 10, 2010
    Would this problem also cause the machine not to go into the spin cycle?
Followed suggestions for LE message and it solved my problem with the OE message - cleaned the drain filter located on the front of the machine near the floor.
Posted on Sep 03, 2007
  • 625 Answers
Check motor first. if motor doesn't turn nothing will work. check belts next. check pump next.
Posted on Aug 25, 2007
SOURCE:
Lg washer WM2277HW getting OE error. replaced drain pump. problem not resolved
Drain hose is clear and not kinked?
pump filter is clean and clear?
drain pump operates/hums when trying to pump out?
Sep 07, 2018 | LG Washing Machines
I have an LG washer/dryer combo wm3987h. I had the OE error which I followed instructions on how to fix now my machine comes on but it does nothing despite me picking a cycle. It does not wash, dry or...
OE = Drain error. Cause: not fully drained within 10 minutes
Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Dec 05, 2010 | LG WM-2277HW Front Load Washer
My LG Front Load washer starts to wash, then when it tries to drain, it stops and shows error code OE. I checked back drain hose and they are not kinked. I removed front filter in bottome left and water...
Hi dear.OE code meaning on Lg washer's"machine unable to drain in 10minutes". You can make a little test.Please remove the filter & pour some water in side drum ,watch for water coming out of filter.If it's slow, tub to pump hose clogged.(there must be some sort of fluff or coin clogging hose)if it's not slow,waters comes out freely, run machine on drain cycle & check the pump motor is it running smoothly?If not change the pump.I hope that helps.Thanks.
Aug 23, 2010 | LG WM2487H Front Load Washer
LG washer with OE error
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 27, 2010 | LG WM-2277HW Front Load Washer
My lg WM2277HW is not draining water. It's filling with water and spinning but not draining the water. An oe error is being displayed. I checked the hoses and they seem fine. I checked the filter and there...
Remove and inspect the drain pump. (access is from the bottom of the washer once you remove all screws holding the pump housing in the front)
If no debris found when removing pump or pump impeller is damaged - replace. PArt number 4681EA2001D.
If found debris when removing the pump - reassemble and check again.
Good luck.
Jul 02, 2010 | Washing Machines
Lg tromm wm2277hw rinse spin error OE
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Oct 26, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have an OE code on my WM1814CW LG Washer
OE code - Check for clogged drain filter on end of hose, bent or clogged dain hose. Make sure hose doesn't go too far down drain pipe.
Hope this helps
Bob
Jul 06, 2009 | LG WM1814CW Front Load Washer
MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
May 06, 2009 | LG WM2277H Front Load Washer
Lg washer serial # 308kw00211
That OE is really DE (drain error). Open the access door at the lower left on the front of the washer. Drain remaining water using the small hose. (at least if it is not plugged) Unscrew and remove the large knob. Clean out filter. If filter was clean, you may need a new pump motor, or something may have made it past the filter and is jamming the pump impeller. You can remove the pump without taking the front off the machine. Do an "Ask Me" if you need to do that, and I'll give you further advise.
Oct 05, 2008 | LG WM-2277HW Front Load Washer
Spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Feb 24, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,356 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
