Question about Pentax Optio W10 Digital Camera
Pentax Optio WP
I press the on/off button and the camera makes a small whirring noise then the screen saver comes on for a few seconds and then goes off. None of the other buttons respond. The battery is freshly charged and I've downloaded the pix I had taken. Any suggestions?
  • 1 more comment
  • stucker1848 Dec 01, 2007
    I have the same problem. How was it remedied?
  • mbinzley Jul 19, 2008
    I also have the same problem with my Pentax Optio WP. It had not been in the water recently and I had just finished taking a bunch of pictures. Turned the camera off. About 5 min later I turned it on again to take more pictures and I got the whirring noise, a series of beeps and then it turned off. Is there any hope of getting this camera repaired or is it time to buy a new one?
  • mark361 Nov 02, 2008
    Same here. Dropped while on holiday in Dublin. Whirring noise, then nothing. Have read that it'll cost more to repair than bought for originally. Very disappointed. Won't buy Pentax again and will tell others to stay clear - it was less than two years old
    Genius:
  • 2,985 Answers
This suggests the lens motor/gearing has failed- I guess other aspects of the system wait for the lens to extend before coming active - possibly due to the waterproofing system. You can only go back to Pentax with this problem.
Posted on Aug 25, 2007
I have the same problem this morning.
I turn it off, than bang it to my keen, because i really not happy.
ha ! it work, however after turn off, it sometimes appear again
not a good machine, but you may try especially you have no choice during your honey moon.
Posted on Mar 16, 2008
SOURCE:
My optio s10 ..as I switch on the lensa is working well, in lcd i see nothing , it's focus...but only black lcd i got every shot the shutter .
Many cameras have a button that switches the lcd screen off. Is there a chance that you may have pressed it by accident? it will be a button with a picture of a box with a vertical line either side of it or LCD/VF written on it. try finding that button and press it once, the screen should come on after a few seconds. If this doesn't work then I suspect there is a fault with the camera.
Good luck.
Jan 20, 2011 | Pentax Optio S10 Digital Camera
Camera will not stay on
the first thing i'd try is charging the battery up,it could be as simple as that.
Mar 18, 2010 | Pentax Optio A10 Digital Camera
Pentax Z10 won't turn on.
Press and hold the playback button for 2 seconds. The camera should turn on and be in playback mode. Switch to Camera Mode by opening the from slider cover. Hope that fixes it. See Pentax Z10 Manual Page 34.
http://www.pentaximaging.com/files/manual/OptioZ10.pdf
Cheers Jon. Sydney Australia.
Jun 10, 2009 | Pentax Optio Z10 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Pentax optio m20 .. on-off immdly
Mar 25, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio T10 turning off immediately
My optio t10 did basically the same thing...turned on, lens goes out, then automatically shut off. I took the advice of a solution listed here for another problem...hit the camera. For whatever reason it worked.
Apr 08, 2007 | Pentax Optio T10 Digital Camera
Cannot turn on my Optio S
When I have that problem I replace the bettery with my spare and I recharge the battery that came out. Works every time. Maybe your battery is worn out and not holding it's charge properly.
Aug 30, 2005 | Pentax Optio S Digital Camera
Can my pentax optio WP can go underwater without a water housing unit? How deep under can it go?
The pentax optio WP can go underwater without a water housing unit. It can only go underwater about 5 ft.
Aug 30, 2005 | Pentax OptioWP Digital Camera
Pentax Optio W10 Digital Camera Logo
383 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
