Question about HP iPAQ hw6915 Smartphone
Head Set When I remove the headset jack the phone will not change over to speaker, no phone calls can be received at all. Anyone have a solution?
  • 32 Answers
You must have a shunt over the jack of the headset. change it or clean it up.
Posted on Aug 25, 2007
How do i fix the volume because i do not have sound? my tv has no volume/sound. tried turning the tv up and down but still no sound
1 - hi
2 - check the jack for headset
- if you heard any sound with headset = your speakers are burned
3 - if you always use this jack for head set its maybe got problem = when push or pull the headset jack if you hear any sound from speakers your headset socket should change
4 - if you didnt hear any sound from both (speaker and headset) it means your ampilifire should repair
May 23, 2010 | Emerson CR202EM9 TV
Cannot hear incoming or outgoing callls
1- Probably the problem is with the speaker = change the in-built speaker
OR
2- The problem is with the earphone jack. = Check if a headphone sign is there on the screen. If yes... then connect & remove headphone/ear-set jack into your mobile few times till the headphone sign is gone from the mobile screen.
Aug 23, 2009 | Samsung SGH-G800 Cellular Phone
When making calls, can not hear ring or person
connect your head set to check if you have the voice on the headset
if yes then you may have to get the phone ear speaker changed
cheers
pls rate the solution
Jun 29, 2009 | LG RUMOR Cellular Phone
My headset is grounded
pushing the jack hard may result in some connections pushed way off, and there is no contact to the speaker. Please see the nearest technician.
Jun 12, 2009 | Cell Phones
Music plays through speaker when receiving messages
its tha connection from your head set to ur fone move it around till u hear it beep in ur head set then it shud play in ur head set hope dis helps
Mar 22, 2009 | Nokia N79 Cellular Phone
Enhancement not supported??
It is either Software or Hardware - both solutions below... best of luck
SOFTWARE
Just in case this setting got mixed up, go to menu - tools - settings - general - enhancement - and make sure your default is set to "Headset". If it is already set to "Headset" then it may be a hardware issue...
HARDWARE
The Nokia detects a 2.5mm jack when inserted and defaults to the standard headset mode (sound comes out through the headset but uses the phone speaker). There could be 2 causes to this (1) short in the headset jack or (2) debris in the headset jack that is making a connection between the contacts.
I recommend that you use a "can of air" sprayed directly in the jack to clear any debris. If this does not work, plug in the phone/headset jack that came with it and ensure that it detects it.
If that does not work, it is a short and you should return it or, if it is out of warranty, get someone skilled to replace or disable the jack (only do this is you have no other option -- Nokia won't touch it after you open and solder it).
Feb 09, 2009 | Nokia N73 Cellular Phone
Nokia E90 Communicator - callers can hear me but I cannot hear
Not certain... but you need to check menu - tools - settings - general - enhancement and make sure your default is set to "headset".
When you plug headphones only (not the headset/mic combo) into the 2.5mm jack, it will go into a headphone mode where you can hear through the headphones but you must speak through the phone microphone - it sounds like it is going into that mode on you. It can only be the setting above or possible a short in the jack (though that doesn't really explain why it is happening only when you receive a call).
If you have 2.5mm headsets (or can pick up a small 3.5 to 2.5 adapter), you can also try having them call you and see if you can hear through the headphones - that would prove it is going into headphone only mode.
Dec 10, 2008 | Nokia 5500 Sport Cellular Phone
Connect head set to sharp lc-26d43u tv
The audio out from those jacks requir amplification and will not drive a head set. Get an inexpensive stereo receiver and run the audio out of your TV to the receiver and use the receiver for your headset.
Jun 29, 2008 | Sharp LC-26D43U Television
Head set icon
you need to change that icon to normal
Jun 12, 2008 | Nokia 6233 Cellular Phone
Nokia 6070
what you need to do is just for you to change your ear piece
Jan 07, 2008 | Nokia 6070 Cellular Phone
HP iPAQ hw6915 Smartphone Logo
69 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
