Question about Haier HLP21E Top Load Washer
My friend has this washing machine and has to turn the water off and on
With every cycle. It seems not possible that they would make something like that. Is that the way it is suppose to be? Should it stop accepting water, but not allow the water to leak. Then accept more water for the rinse? Anyone have this same model? Do you have to get up to turn the water off when its ready to wash.
  • Anonymous Dec 29, 2007
    My machine keeps adding water, never goes to next step. Whatever the water level is, it doesn't stop accepting water.
    Problem Solver:
  • 5 Answers
To both of your problems... yes, this washer is electronic, and won't even continue the cycle until it's full. It has a pressure switch just like a normal washing machine, and it sounds like yours are faulty (seems to be a common problem with the HLP21E). You can try tearing it apart and recalibrating the switch yourself, but if you're not familiar with that, just call Haier. As of today you should still be under the full replacement warranty if it was new when you posted this ;)
Posted on May 21, 2008
  • 291 Answers
Need more info not sure i understand but sounds like a pressure switch or water valve problem
Posted on Sep 03, 2007
What can cause a washer to not fill with cold water during the wash cycle?
well it would seem these are the possibilities:
1. cold water not turned on
2. hose kinked
3. inlet valves not working
4. wiring issue
5. control board issue
oh and plugged inlet fill filter
good luck
Sep 02, 2015 | LG Washing Machines
Kenmore heavy duty 70 series washing machine, water won't stop
sounds like the washer water inlet valve is bad or the water pressure/level switch is bad or clogged or disconnected.  without knowing model hard to diagnose beyond this.
Jul 30, 2010 | Kenmore Washing Machines
Roper RAX7245KQ0 Problem: Washing Machine Leaking Water
This is the best designed life long lasting Whirlpool washing machine. This core design is more than 35 years old and it is so good Made in USA design. Cannot go wrong.... Coming from 1969 Moon landing time where Made in USA matters....
Most of the time in this design, the drain pump leaks. Is the leak is coming from front middle. It might be the drain pump. Careful observation is needed. Check the drain pump seam for possible water marks or brown color water marks. Make sure before changing.
Make sure it is the drain pump. Can be something else too.
Part description for water pump for your model with a video clip how to change it.
Oct 09, 2017 | Whirlpool Washing Machines
Agitator no longer moving
sounds like you may have burned out the lid switch. if it is not working the timer thinks the lid is not closed and will not advance.
Oct 04, 2009 | KitchenAid KAWS850L Top Load Washer
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Water from soap dispenser when spinning
Thanks this solution cured mine and my friends machine with this problem of water coming out of the soap dispencer.
Jan 12, 2009 | Washing Machines
Maytag Neptune MAH4000
Are you getting cold water to fill ?How is the water pressure?Timer maybe at fault here.
Jun 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Asko 12605 overheating the wash water
(even not taking in hot water when filling before the wash stage which seems good)
The washer fills with cold water then heats it up 3 degrees a min. Your problem does sound like a faulty thermostat. Especailly if the glass door does get hot even if it is on 85f.
May 29, 2008 | Asko Washing Machines
Smartdrive 703 Model Washing Machine Leaving brown stains in clothing after some wash cycles. Stains are small and seem to be something coming through to the clothess from the slits in the drum holes. ...
if you do cold washs all the time you get a build up of sludge between the drums you need to fill it with hot water and let it soak for a few hours and then put through a high wash to rinse out,no clothes.Or you can remove the drum and wash it .hope this helps
Mar 14, 2008 | Washing Machines
Washing machine
Shut off power and the valve on wall. Unscrew the hose from the wall faucet & check for blocks in the small screens, and on machine water entry valve also. Could be just some dirt or something; the screens are important. If possible also check the dispenser area.
Jan 01, 2008 | Washing Machines
Haier HLP21E Top Load Washer Logo
233 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
