Question about Pioneer SIR-PNR2 SIRIUS Radio Receiver
Static sound ok i will start from the beginning, i had the sirius starmate 4 in my car and it worked flawless, i then decided to upgrade to a new pioneer headunit and so i swapped and oppted for the Pioneer SIR-PNR2 Sirius adapter to rid the need of the starmate so i hooked it all up and called sirius and they activated it and it works just fine but when music is playing it makes a popping like noise, almost as if my speakers are blown but that can not be because it just happens when i am listening to sirius? any tips on why it would be doing this would be greatly appreciated
  • 33 Answers
Some Pioneer radios allow for seperate audio controlls between FM CD and External sources like you Sat Radio. It may be that your settings are out of wack (Prob the factory setting which is crap), try that out and let me know.
Posted on Nov 28, 2007
My Starmate 5 constantly has to acquire signal in my car at home it works perfectly.Any suggestions?
Check the antenna's connector for your car based antenna. Sometimes the little finger tabs need to be gently pushed back towards the center to make a better connection. Be careful not to move them more than a precision screwdrive blade's width or you might snap it off.
Jul 08, 2010 | Directed SIRIUS Starmate 4 Satellite Radio...
Sirius starmate 2replay has no sound. how do I go
When you hit the menu button go to FM transmitter and make sure is is turned on, and sellect a frequency
to set it to that is not being used by a radio station, tune you radio to the same frequency. if you are using the audio out on the starmate to plug directly into an aux in on you stereo, there should be a audio level adjustment in the menu as well.
Aug 17, 2009 | Rio SIRIUS Starmate Replay Receiver
Starmate boom box has no audio
Go into the menu and make sure the audio out is turned up
Jul 05, 2009 | Rio SIRIUS Starmate Replay Receiver
Logo only
Bad news my friend. That model isn't supported anymore. Sirius is pretty good about replacing the radio for free and discounting the accessories. You will get one for free. The docks are reasonably priced. The boombox you might be able to get a discount for. The new docks are more designed for multiple units should this happen in the future to you again (like Stratus radios).
There isn't much to service on the radios. If the board is dead it isn't worth fixing. It's cheaper for Sirius to replace it.
Aug 26, 2008 | Sirius Satellite Radio Sirius Starmate ST1...
Distorted sound
I have had this problem also. While I haven't completely fixed it I have figured out the root of the issue. Within this unit there are two circuit boards. Between the two boards is a white connection. It appears this connection becomes loose or is susceptable to the heat that is generated from the unit. I've tried teasing out the pins within the connection to see if they can get a better fit together. This will work for a little while but then the static returns. I'll post back if I come up with a final solution to this problem.
Apr 24, 2008 | Sirius Starmate ST2 Satellite Radio...
I have a starmate I think it is a older one and the sound doesnt work
My Sirius Starmate did the same thing last night. Playing with the line out got it to work for about one second.
Dec 31, 2007 | Sirius Starmate ST2 Satellite Radio...
I had the same problem with mine. I purchased the Sirius FM direct adapter and now it comes in crystal clear.
Aug 26, 2007 | Sirius Satellite Radio Sirius Starmate ST1...
Sirius Starmate 4 - locks on the "Sirius: screen
with starmate 3 press at same time menu +memo+band with the radio on (with sirius screen only)
Aug 21, 2007 | Rio SIRIUS Starmate Replay Receiver
Sirius XTR1 Receiver cycles on dog screen with beep - keyboard locked
Hello, I had the same problem with my xact xtr1 and I was advised by xact that they have no repair process in works and most likely wont. They did say let it run for 10 minutes and once you have a menu switch to factory defaults which proves to be a worthless fix. I would have to pay $39.95 for a new radio...horrible customer service. The bright side is that Sirius will not charge me the $75.00 transfer fee as a good faith gesture. I have decided to switch to another radio and leave the Xact brand out of the equation, if there is no upgrade or modification to the existing equipment why set yourself up for a future failure.
Aug 05, 2007 | Xact Communication XTR1 SIRIUS Radio...
Pioneer SIR-PNR2 SIRIUS Radio Receiver Logo
179 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
