Question about LG enV VX9900 Cellular Phone
Navigation aint working
When i press on navigator it doesnt load and its stuck on the screen
  • ChrisRod Jan 09, 2008
    I hit: Menu > Navigator > 1. Navigator. Phone get stuck on screen unless I press [[END]] or close the screen. Tried the "Location" fix, and it didn't do any good, it was already set to {Location On}. I switched between {E911 Only} and {Location On} just to see if it did any good, and it didn't. I tried recycling power (removing battery), and waited forever to see if the screen was just loading slowly. Nothing. If it means anything, I've had the problem since New Years Eve.
  • Cody93 Jan 09, 2008
    If it did expire, how do u get it back?
I checked under Menu > Get It Now > Get Going and it said my [[Navigator]] was expired on January 1st, 2008. That's complete BS because I pay monthly for the service, and it should never expire... I did try upgrading the version, with no luck. Tomorrow I am going to the Verizon Store and giving them an earful. Update to follow...
Posted on Jan 09, 2008
The program most likely expired. The same thing happened to mine.
Posted on Oct 27, 2007
Follow this: 1. Go to Settings & Tools. 2. Select option 5 (Phone Settings) 3. On next window select option 5 again (Location) 4. After the selection is made you should see 2 selection options. a.) Location ON & b.) E911 only. 5. If the selection is on "E911 only" your Navigation system will not work. Change the election to "Location ON" and after selecting this option, exit and go to Navigation.
Posted on Sep 08, 2007
SOURCE:
My samsung juke phone won't work. If I take out the battery and charge it, the screen will flash. The second I press the prongs together, it stops working.
You may need to reset the phone, but it will delete everything on the phone. You may follow the steps below:
  1. From the main screen, press the center of the navigation wheel to choose Menu.
  2. Select Settings & Tools then press the center of the navigation wheel to choose OK.
  3. Select Phone Settings then press the center of the navigation wheel to choose OK.
  4. Select Security then press the center of the navigation wheel to choose OK.
  5. Enter the lock code then press the center of the navigation wheel to choose OK.
    The default lock code is the last 4-digits of the mobile number.
  6. Select Restore Phone then press the center of the navigation wheel to choose OK.
  7. Select Yes to confirm then press the center of the navigation wheel to choose OK.
Jul 26, 2016 | Samsung Cell Phones
Navigation turns on says loading but then goes black
IF NONE OF THE ABOVE SOLUTIONS DOESNT HELP THEN CHECK THE CD UNIT IN THE BACK THEY TEND TO GO BAD GIVING THE SAME BLACK SCREEN RESULT.
May 01, 2014 | 2006 Acura TL
My naxtar gps wont load into the maps. it loads through the first screen then i hit navigator and it takes a bit loading then comes up with "error, cannot start the main navigation engine!...
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
The link below has the operating manuals and software available and contact numbers.
Thanks for using Fixya, please accept my solution.
http://www.nextar.com/frontend/gps_navigation_systems.asp?MODEL=43NT&subpr=&categ=
Jun 01, 2011 | Nextar 43NT GPS Receiver
Problem with PCM Navigation
Hi I have a 2006 Caymans S and have exactly the same problem, everything works except the Sat Nav!
In the navigation option menu, it lists 0 satellites being picked up
The dealer looked at it today and replaced the GPS antenna, but didnt fix it. They too mentioned about a new unit...
I will post if I solve it, but if you find out what is wrong I would really like to hear about it.
Dec 15, 2009 | 2003 Porsche 911 Carrera
The screen is stuck on the align screen i reset the phone and attempted to reload windows mobile and when the align screen came up i tapped it but it wont go away
Did you perform a hard reset? To do this:
  1. Slide open the device to expose the QWERTY keyboard.
  2. Press and hold the center of the 5-way navigation pad.
  3. While holding the center of the 5-way navigation pad, use the stylus to gently press and release the reset button.
  4. When Clearing Data... appears on the screen, release the center of the 5-way navigation pad.
  5. When prompted, tap the screen to setup the device.
Sep 07, 2009 | Samsung SCH-i760 Smartphone
Forgot password
  1. From the main screen, press the centre of the navigation wheel to choose Menu.
  2. Select Settings & Tools then press the centre of the navigation wheel to choose OK.
  3. Select Phone Settings then press the centre of the navigation wheel to choose OK.
  4. Select Security then press the centre of the navigation wheel to choose OK.
  5. Enter the lock code then press the centre of the navigation wheel to choose OK.
  6. Select Restore Phone then press the centre of the navigation wheel to choose OK.
  7. Select Yes to confirm then press the centre of the navigation wheel to choose OK.
Aug 09, 2017 | Samsung SCH-U470 Juke Cellular Phone
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
1st Gen. Ipod Nano wheel control wont work
Greetings,
For instructions too long to post in here - click on this link
fxnlogo_s.png Technical Support, Instructions & Repair Service
Aug 01, 2008 | Apple iPod MP3 Player
MY NEXTAR MA9336A1S IS STUCK ON THE NEXTAR SCREEN
Apr 06, 2008 | Nextar MA933A MP3 Player
Navigation cirle
yes what ever you say is correct. What to do.
Mar 29, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG enV VX9900 Cellular Phone Logo
82 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
