Question about Sharp UX B20 Plain Paper Inkjet Fax
Reprint last incoming fax
How can I reprint the last incoming fax that didn't initially print properly due to ink cartridge?
I'm afraid you are out of luck. Once an attempt is made printing and no error message about the ink cartridge condition is apparent. Then that's it, it is deemed successful.
Posted on Sep 05, 2007
I want to reprint the last incoming fax because it was unreadable. I also just replaced the toner drum. Still get "replace toner drum" message.
You can't do a reprint of the last fax it's not possible on any fax machine I'm aware of you'll need to contact whoever sent you the fax to resend
Mar 16, 2015 | Brother MFC 4800 All-In-One Laser Printer
REPRINT FAX
I suspect you look in the history and pick the last job printed if you are in a confidential environment then all the information would be deleted after printing and you would need to re-send the original document again.
Good Luck.
Aug 07, 2014 | Xerox WorkCentre 3615/DN - multifunction...
Is it possible to reprint a fax I received on my Pixma MX310
Hi! have you tried this:
http://www.fixya.com/support/t6754616-canon_pima_mx340_printer_fax_machine
Nov 29, 2012 | Canon PIXMA MX310 All-In-One Printer
NEED TO REPRINT RECEIVED FAX HP OFFICEJET 4500
Yes, You can.
Press Settings (The Wrench Button)
Navigate to "Print Report" - Press OK
Navigate to "Reprint Faxes" - Press OK
"Reprint All Faxes" - Press OK
Or Navigate to "Reprint One" - Press OK
Navigate to Date/Time Received of fax to reprint - Press OK
May 19, 2012 | Brother IntelliFax-2820 Laser Fax
Can I reprint an incoming fax? I ran out of ink and the copies are unreadable? Pls tell me how to reprint a fax on my 6310 officejet.
If the printer doesn't have memory function itself... they're not going to reprint.
However, for your HP6310, they do have a function for 100 pages of fax memory.
Fo go fax manu (on your left side, by facing printer), press the fax set up and will see the reprint for fax.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 02, 2011 | Office Equipment & Supplies
Need to print a fax in memory, machine was turned off and unplugged
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory
option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Reprint a fax
Sorry, once a fax is printed, it is gone from memory.
May 31, 2010 | Samsung SF360 Plain Paper Inkjet Fax
Can I reprint a fax that I just received?
If you want to reprint a fax because the print cartridge was empty or if the fax was printed on the wrong type of media, you can try to reprint it. The amount of memory that is available determines the actual number of faxes that are stored for reprinting. ... These faxes are stored continuously.
here's how if you have this accessibility..
Press "Setup" on the control panel of your fax machine. Most fax machines will have an LED display panel on the front of the machine. The panel will usually include on screen prompts and help options. Some fax machines signal the user if they have faxes stored in memory and prompt the user to "print faxes" or "clear memory," but you need to make sure that you don't accidentally clear the memory or you will lose all saved faxes.
Use the arrow keys or number pad as directed by screen prompts to select "Fax Setup Menu" and then press the "OK" or "Start" key.
Enter the security code, PIN, or user authorization code if required. The security code or PIN protects sensitive information and prevents unauthorized use of the fax machine memory. If you haven't set it up you don't have it.
Navigate to "Receive" or "Print Faxes in Memory" and then press the "OK" or "Start" key as directed by the on-screen prompt. The last fax stored in the machine's memory should begin to print.
Repeat the above steps for each fax in memory if you need a different one.
Hope this helps and isn't clear as mud!
Happy new year.
problem? make and model # please.
Jan 01, 2018 | HP Officejet 4110 All-In-One InkJet...
Reprint last fax
JUST OPEN THE TOP COVER PUT IN NEW INK CAARTRIGE THEN FAX WILL RESUME PRINTING FOM MEMORY AS LONG THE POWERS WASNT TURNED OFF
Dec 31, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp UX B20 Plain Paper Inkjet Fax Logo
457 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
George Mclaughlin
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
