Question about Cowon System iAUDIO X5 MP3 Player
IAUDIO SAYS HHD ERROR
I AUDIO X5 DISPLAYS HDD ERROR ON THE SCREEN AND IT JUST CUTS OFF AFTER THAT WHAT DO I DO
  • 3 more comments
  • morbert Nov 08, 2007
    iaudio m5 displays hdd error when turned on
  • Anonymous Dec 30, 2007
    I tried to replace HDD with a brand new one - still the same HDD error message...
  • alogo May 26, 2008
    iaudio goes black after displaying the hdd error message
  • guerymagic Jul 24, 2008
    Hi, I did format in fat 32 using partition manager, also I re-create the folder firmware and pasted the firmware inside, i turn on and I have a HD error and the iaudio swich off. what could be the problem?
    Thank you for your help.
    Guery
  • Anonymous Mar 29, 2009
    HDD comes up when its turned on, and screen goes off. mine got a bit damp though, so im not too hopeful about fixing it! :(
I also had this error. I assume this fix will also work on the X5 and maybe M3.
This can also be used to upgrade the HDD to a larger size!
I love my M5 and was gutted when it broke, it sounds brilliant and even in June 2009 it beats the competitions tiny, flashy, colour screen malarky by being solid, ugly, un-nickable and NO DAFT SOFTWARE! That last point is integral to fixing this fab machine.
Mine was caused by a chair leg placed on the unit... so I pretty much knew for sure the error truly was a HDD one.
- I bought a new HDD (hard disk drive), a Toshiba MK3006GAL (30gb) to replace the original MK2006GAL (20gb) off ebay. My fixed M5 is now 30GB! I'd be careful what drive you use to replace the original, I have no idea which work and which don't work. Stick with Toshiba probably.
- If you have an external drive caddy for 1.8" HDD's or some means of easily formatting the disk like a cable, format it to fat32 filesystem now. if it's secondhand your seller might do this for you if you ask nicely. Skip the linux steps if you can do this.
- Unscrew the back of the unit with a properly sized precision screwdriver, you don't want to ruin the heads on the screws mangling them with the wrong tools as they won't go back in!
- *gently* peel back the silver tape and move the red wire aside. The tape is conductive to stop static from the HDD messing things up and vice-versa.
- remove the back tape section and remember where it goes.
- remove the HDD and gently remove the delicate connector cable
- replace the HDD and put everything back as it was, making sure the black tape is in the same place and the silver tape is firmly attached (as it is meant to conduct electricity). Screw it all back up.
SKIP THESE STEPS if you previously formatted the HDD and continue where it says NOW:
- Windows was useless as it finds the device but you can't do anything to it, so I used the Ubuntu linux instead. There is probably a similar method for macs. Maybe you could use DOS, but god help you! If you hate linux, maybe Partition Magic for Windows can be used but this is only a suggestion and may be a totally useless one as I didn't try it.
- Get Ubuntu linux (or your own preferred distro) live CD (or install and enjoy a windows free life!).
- Load the livecd.
- Load Gparted (System>Administrator>Partition Editor, or "sudo gparted" typed in the terminal)
- Find the unformatted new HDD from the drop down menu e.g. SDA will be your computers HDD, don't touch that! SDB will either be your M5 or another internal HDD. You will recognise the correct drive by noticing it has 'unallocated' (i.e. unformatted) space of the same size of your replacement HDD, and won't be half full like your PC's drives (which you DONT want to format!).
- Format it to FAT32 (the same as a pendrive).
- Remember to 'unmount' the filesystem when you unplug or it may corrupt. If you have no idea what I'm talking about, leave it plugged in while you turn off the computer, and remove it when the PC is off.
NOW:
- Either using Linux or other means, you have an M5 with a new HDD formatted to fat32.
- Download the latest firmware from Cowon.
- Plug in the M5 into the PC
- The PC >should< recognise this is an IAudio M5, and you should be able to access the new empty disk. I did this step in Linux, so its probably best that you do too.
- Create a new folder on the M5 called "FIRMWARE"
- Drag the firmware file into the FIRMWARE folder.
- Unplug the unit safely (i.e. unmounted) and turn it on.
The unit runs a firmware update and recreates the software on the new disk.
Voila! You have a repaired M5!
Connect to a PC and add your music back on. You did keep a backup, right? ;-)
Hope I've helped everyone!
Posted on Jun 26, 2009
I have same problem and dont know what i can do with it
Posted on Jun 24, 2008
Ide 0 error I have a 2535 and it displays on the screen ide error #0 replace disk and press any key
Replace the hdd and reinstal windows or go into the bios and find out why the hdd is not available.
Jul 23, 2014 | Toshiba Computers & Internet
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
Asus g50 vt-x5 will not POST or boot
Have you tried connecting it with another display?
Jan 06, 2013 | ASUS G50V-A2 15.4IN Notebook
Audio communication error message is displayed on the 2010 pajero screen. However, CD works but does not indicate track or any other info, simply error message
audio communication error message is displayed on the 2010 pajero screen. However, CD works but does not indicate track or any other info, simply error message
Nov 27, 2010 | Car Audio & Video
It has an error e 74
E74 means a hardware malfunction, might be due to a bad memory storage deive attached to the Xbox 360 which is the hard drive (HDD). Steps to do:
• turn of the console and remove the HDD
• restart the console without HDD
• if it works without the E74 error, the HDD is bad and needs replacement
• if still having the same error even without the HDD, it's is an internal hardware failure inside the sytem already
If all else fails, please contact Microsoft Xbox Support for it ti be repaired. Hope this helps.. Cheers!
May 11, 2010 | Microsoft Xbox 360 Console
ERROR CODE E602-0003 What is this?
E602
1) Are the connection and the cable of the connector (J1017) on the main controller PCB and the connector (J1551) on the hard disk drive normal? NO: Correct the cable connection.Hard disk drive (HDD), Main controller PCB
2) Try replacing the hard disk drive and downloading the system software.Is the problem corrected?
YES: End. NO: Replace the main controller PCB.
3) HDD unit.
Remove the rear upper cover and the reader rear cover. Remove the three screws, and detach the cover, Remove the two screws and disconnect the two connectors then, remove the HDD unit. Remove the six screws and detach the HDD When mounting the HDD unit,be sure that the flat cable is under the plastic sheet of the HDD upper case.
Solution 1# :
It can be a Sector Problem ,to resolve it just press 1&9 keys at the same time the machine started the HD Diagonose and it repared the sector error without replacing the HDD .
Solution 2# :
try to go in to disc check service mode to clear the sectors ,this should work if it doesnt you will need to replace the hard drive .
Solution 3# :
Try HD clear & then HD check for every sector in service mode. Then try to upgrade system software;If nothing works change hard disk ,format & install system software. Posted by Kuyung at 5:50 AM icon18_edit_allbkg.gif Labels: error code 602-0003 IR5000, error code 602-0003 IR6000
May 07, 2010 | Canon imageRUNNER 5000 Copier
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Apr 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Pioneer DVR-540HX DVD recorder Error message 'REPAIRING HDD'
Greeting, I have same problem too, and now recorder is in warranty service. HDD sucks. This recorder is piece of ****. HHD is noisy and poor quality.
Stay in peace
Nov 17, 2007 | Pioneer DVR-540HX DVD Recorder/HDD...
Axim X5 Align Screen Loop
I am by no means an expert but I have had the same problem that you are having and I found that after I took my X5 apart and cleaned around the underside edge of the plastic housing frame that was at the edge of the screen the problem went away. I also cleaned the front of the screen very well and put a new back-up battery in. I have not had the problem since.
Sep 05, 2007 | Dell Axim X5 Pocket PC
Cowon System iAUDIO X5 MP3 Player Logo
1,469 people viewed this question
Top Cowon System Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Cowon System Audio Player and Recorder Expert? Answer questions, earn points and help others
