10 amp fuse keeps blowing as soon as you turn the key in the ignition switch/ thus causing the bike not to start or turn over/ every thing else works fine / the other 2 15amp +10amp fuses are ok. bike was ok till yesterday .had been left for 4 weeks /but run +started fine until yesterday .
SOURCE: blows ignition fuse when key is turned on
Look for a grounded wire on the ignition switch or a break in the wiring leading to the fuse. Wiring system on motorcycles are a close system with only the battery being grounded to the frame. Any loose connections or breaks in the wires that will allow the current to jump to the frame with cause you tons of fun.
SOURCE: 10 amp fuse for headlight keeps blowing
Sounds like a bad wire arking against medal. Look for the bad wire and tape it or replace it.
SOURCE: Ignition Fuse keeps blowing
From another forum,
"You've got an exposed hot wire somewhere in the power circuit that's
grounding out and causing resistance in the wire. Not sure how to help
on this one, electrical problems are damn near invisible, but I'd start
looking for a burn mark or scorched insulation on any of the wiring
leading up the relay, starter, or main fuze block in the tail."
SOURCE: 10a ignition fuse blowing
check wires under seat and around frame sounds like you have a bare wire somewere.
SOURCE: 200o 1500 vulcan classic. My ignition fuse blows
you have a short somewhere in the ignition line. check all connections at coil, check for worn spark plug cables grounding on block.
