Question about Kenmore 24 in. 16059 Built-in Dishwasher
Kenmore Dishwasher 665 16059401 - Control lights flashing Not working
A few days ago the lights on the control panel started flashing. It ran one partial cycle and then quit. Now it will start, but within a few seconds turns off, and the start light flashes. If you hit it the cancel light turns on and flashes and then sometimes both do. I tried the heated dry normal wash key dance but it isn't working. Any suggestions on how to reset or fix this thing?
  • 2 more comments
  • JessRN Aug 26, 2007
    We turned off the breaker for an hour. No luck. Sometime today it started flashing clean instead. When I say "start" it had filled at one point and then it pumped it out at one point. When it started you could hear water going in to it as well. The overfill protector moves freely. It also clicks when you move it. The door latch fastens securley too.
    We took apart the keypad console and reconnected it. It is still flashing Clean. If it means anything it flashes 7 times, pauses, flashes 7 times. Thanks for the help.
    We tried hitting those keys twice each in that order within 6 seconds. It didn't light up all the keys. I'm curious why now the clean light is blinking when yesterday it was the cancel/start button were the ones Blinking. Thanks again for the help. Awating more ideas
  • JessRN Aug 27, 2007
    Which one is it the Cancel or the Start button? Mine are two different buttons.
  • JessRN Aug 28, 2007
    That didn't work either and now the clean light and the cancel light are flashing. I'm assuming this means it's a bad key pad?
  • 725 Answers
Hi Have you tried resetting your house breaker to your dishwasher, by turning it off for 60 secs. then back on again? this should reset your dishwasher. By Start can you hear the pump out. or can you hear water filling the dishwasher?..if it only pumps out..it may be the Overfill protector. Check to make sure the overfill protector moves up and down freely. The overfill protector is located in the left front corner of the tub it looks like a little hat. it should move up and down easily. and you should feel/hear a click that is your float switch. also check the Door latch. Open and close the door to make sure the door latch is securely fastened. Next you may take off the console, and reset that control board to keypad console connector , by taking that loose and reconnect it. If that doesn't work, then you may need a new keypad console assembly. let me know what you are doing to do? I can help you somemore.
Posted on Aug 25, 2007
  • 2 more comments
  • Franklin Ouchida
    Franklin Ouchida Aug 26, 2007
    The seven flashes of the clean light
    is the problem is an insufficient rise in water temperature during a pre-set time period. The heater fault-detection program that was added to the electronic control is designed to shut down the dishwasher if the board-test for proper water temperature rise is not sufficient.
    the unit will drain and the clean light will blink seven times.
    you will need to find out why the water temperture was not sufficienet rise could be wiring to/failure of the control,
    heating element
    the thermistor
    the inlet valve
    door switch
    motor
    capacitor
    to reset
    within 6 seconds press Heated Dry, Normal, Heated Dry, Normal'
    all the lights should light up. and go into self Diagnostic Mode let me know if it helps..
  • Franklin Ouchida
    turn off for 60 sec. then try
    within 6 seconds press Heated Dry, Normal, Heated Dry, Normal then press cancel/start. this should reset.. if it will not let you it must be a bad touch pad and/or control...and they must be replaced... I just hope it works for you..
  • Franklin Ouchida
    Franklin Ouchida Aug 27, 2007
    press cancel at then end
  • Franklin Ouchida
    Franklin Ouchida Aug 28, 2007
    one thing you can try before replacing your key pad .. after turning off the power unscrew the control from the door. uplug the key pad from the control(ribbon wire )and use an pencil eraser to clean the contacts. reinstall the ribbon wire. and rinstall the control.. let me know if yout try it..hope it helps
SOURCE:
Why is heated dry blinking?
FIXED Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry ...
www.applianceblog.com/.../40588-Kenmore-dishwasher-lights-flashing-...
Aug 26, 2013 - 10 posts - ‎3 authors
Thread: Kenmore dishwasher lights flashing: "Hi Temp" & "Heat Dry" ... A few months ago, we had a brief power outage and the next morning, noticed the "Hi Temp" and "Heat Dry" lights were flashing. ... Well since then, the dishwasher intermittently stops mid-cycle and these same lights ... Thread: GE Eterna QuietPower 2 Normal and Heated Dry ...
Feb 24, 2012
Kenmore Elist 665 dishwasher Smart Wash red light ...
Dec 23, 2011
Heated dry blinking +17 times - ApplianceBlog
Nov 14, 2010
Heated Dry light blinking
Nov 7, 2010
More results from www.applianceblog.com
Why won't my dishwasher start and why does the "Heated Dry"
www.shopyourway.com > Manage My Life > Questions
Nov 16, 2009 - When I hold down the Heated Dry button to turn the control lock on it ...my dishwasher start and why does the "Heated Dry" light keep blinking ...
Dec 01, 2015 | Dishwashers
Why are some of the lights and some of the buttons on my Kenmore Dishwasher Model 66513743K601 not working?
Why would you not try removing it and cleaning the contacts?
Yes; the pannel will need to be replaced if that does not work.
Sep 07, 2014 | Dishwashers
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Why won't my Kenmore dishwasher display work properly?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Kenmore dishwasher wont turn on seems to have no power.
Check the breaker in your breaker box, it may have tripped. Reset it and run the dishwasher. If it trips again, have the dishwasher looked at by a professional service person.
Feb 13, 2012 | Kenmore Dishwashers
My Whirlpool DU1145XTP won't turn on. Clean light
Check the themistor in the control panel. Radio Shack sells these for about $1.30 each. I replaced the one in my dishwasher three years ago and have had no issues since.
May 16, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Kenmore dishwasher 665 Lock on light
You may have a stuck button as this will cause flashing of lights, try pushing button and see if it returns if not strike lightly above it with plastic spoon etc.
If this does not work u can buy the control panel from Sears for 190.00 but first go to searspartsdirect.com then type your model no. In required space click on shop parts on appropriate model, then go to troubleshooting then to won't start, then go down to how to replace control panel.
According to instructions you will only need torx screwdriver and less than 30 minutes to replace.
Jul 13, 2017 | Kenmore 16602 / 16604 / 16609 Built-in...
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Under cycle setting the quick rinse light keeps flashing and dishwasher does not run.
Hey Jim, if your model starts with 665 there was a service flash on this unit concerning your problem. SF-22-715. Dishwasher stops in mid cycle. The control board was redesigned to eliminate this problem. The service flash states that if only one indicator light is blinking it's usually a stuck or shorted keypad. I would check with Sears and see if you are covered under this service flash. Catriver...post back.
Aug 28, 2006 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore 24 in. 16059 Built-in Dishwasher Logo
303 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
