SOURCE: Temperature Gauge in 2000 Honda Civic LX
hi from uk from your symptoms of what happened re temp guage risen suddenly it would indicate the temp sender unit on the engine has blown ie is earthing to engine via its screwthreaded body this is just a matter of replacing with a new sender unit hope this helps
SOURCE: 2000 pontiac montana wipers stuck
This has happened a couple of times on my 1999 Pontiac Montana. Here's what I did to fix. Open the hood. Remove the shield over the the wiper cam mechanism on the passengers side. This is easy to access. Road salts and other dust and dirt gets in there and causes the sticking problem. Spray WD-40 in between the parts. Get in there with that little red spray straw and saturate it good, flush junk out. Get in the car and try the wipers. If I remember, you might have to manually place that little knob or lever on top of the cam in the opposite position to get it to resync, but try it first. Be sure the wipers are off when you're spraying the WD-40 so you don't injur your hands. I've had to do this twice and it worked both times.
SOURCE: 2000 Ford Expedition and the windshield wipers work randomly
I've heard of this before. Here's a detailed article on how to fix it - http://www.fordf150.net/howto/fix-intermittent-wiper-problem.php
SOURCE: I have a 1998 Ford Explorer XLT. windows and wipers won't work
Check your fuses. Some under the dash and some under the hood.
SOURCE: 2000 VW jetta VR6 windshield wipers wont work
first try the fues box see if you have a blown fues, next if you put your wipers on can you hear the motor running for them? if you can the linkage has poped off from the motor, its a bit awkward to get it back on and no gaurentee that it will saty on, you might have to replace linkage, or, it might be the cogs on the actual wiper arms have splayed and are now smooth so they dont grip to move, you can take them off by the nut on the arm , get a can (coke can or simular) cut a rectangle out of it the hight and width if the cog, rap it round the cog, (make sure it does not overlap on the ends) and force the arm back into place and then do the nut up, this is just a short quick fix if that is the case you will have to replace the motor, also you can check the relay to the motor in the fues box, give it a tap a couple of times it might work again if not replace it...hope you find these sugestions helpful
