Question about Kenmore Oasis HE 27082 Top Load Washer
Lid Lock light stays on
I just purchased a Kenmore Oasis and the first day it worked fine....I just went to put a load of clothes in today, put the detergent in and shut the lid, pushed start and the lid light blinks and beeps...won't go off, I have opened and closed lid several times and nothing...please help!
  • Aliciab Apr 28, 2008
    I've added clothes to my washer, shut the lid, pushed the start button, and the LID code comes on, and the washer will not start
  • 868 Answers
You are eligible for a refund. TAKE IT ! ! This should be a learning experience.Since when did the consumer have to be come the repairman WHEN ITS UNDER WARRANTY ,C,MON NOW!!!
Posted on May 26, 2008
Washer will not power on and lid is locked
Unplug it and wait a minute or two, the lid will release. Take out the clothes, plug it back in, put it in spin and close the lid. If it goes back to work, good. If not, check for repair clues.
Dec 01, 2013 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Nov 18, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Oasis, model 110 270 826 02, serial #CT3270410, that I just had the touch pad ERC control part (8564392) replaced last week. Today when I went to use it, the DU comes up on the control panel...
The DU error code indicates that the control detects a problem with the washer door (lid) unlocking. In this situation, the failure is normally caused by a failed door lock assembly. I provided technical information on this failure in the first image below. You can use this information if necessary to verify a failed lid lock assembly. The control is apparently sending the voltage to the lid lock mechanism to unlock the door but is not sensing that the lid is unlocked. There is a chance that you have a wiring failure or a bad control board so it is best to thoroughly diagnose the failure if possible before replacing components. Be sure that you unplug the washer before accessing internal components. If you determine that you have a failed lid lock assembly, you can use the procedure shown in the second image below to replace this component.
Jan 10, 2011 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis HE model number: 110.27072603 washing machine shows LID error code. It wont work at all.... went half way through cycle... help.
this washer has a lid switch problem...or possible main board failure, but lid does concentrate on the lid safety switch. If you remember when you open the lid it stops..well, its a safety feature and prevents tub from spinning with lid open...this one is more difficult to service if your not use to working on washers...try unplugging machine and leaving off for awhile...does the door lock? check switch for lid fault
Nov 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Lid does not lock will not take cycle instructions
Kennmore Oasis washer; I just replaced the lid locking mechanism (8563937) with the upgrade (W10059230) from
Jul 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Power comes on and all lights come on, but the washer will not start the wash cycle. After the start button is pushed the lid lock will not lock.
That is why the washer won't start. Replace the lid lock. It is there to stop anyone from putting their hands inside of washer when it ia agitating, by stopping power to the motor.DO NOT try ANY attempts to mmake it work!!!! Injury may result
Feb 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Lid lock not on, and machine is not going through
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 17, 2009 | Kenmore 24032\24036 Top Load Washer
My Sears 500 washing machine stops in middle of wash cycle.
timer problem or maybe the lid switch is going bad. Im curious if the motor is getting hot and shutting down... go to call .. ask for mark
Jun 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
Machine went dead with clothes and water in it
with putty knife press in along front edge between top and front about 2-3 ins from outer edges on release clips top will lift up suspect bad lock assembly
Jul 04, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
208 people viewed this question
Sal De
 Brian Main
Brian Main
