Tv was on ..then it went off will not turn on when it is plugged in it makes a winning sound
I replaced the Flyback and Horizontal Output X-Tor, No change. I could hear the power supply come up when I plugged it in, B+ was present and I had Horizontal pulses on the base of the Horizontal Output X-Tor. I was look through some RCA bulletins and came across TV-03007. Basically it says that CP23 a 2.2uF 50 VDC Cap would cause the set to start intermittently or very slowly. As per the bulletin I replaced this cap with a 4.7uF 50 VDC Cap. That was it! it came right up and has been working ever since. This also pertains to chassis' "AA1, BA1, CA1 and CB1". Good luck, I hope this helps.
