Question about Sony KV-35S42 35" TV
Tv Flashes When turning my tv on, it takes about 5 minutes to get any picture at all, then it takes about another 10 minutes with the picture flashing on and off, until it finally settles. I am noticing it getting worse every time. It now also seems to flash on and off if the picture on the screen is too bright or action-filled.
  • Anonymous Nov 08, 2007
    Hi, I was having the exact same problem with my 35 inch sony trintron KV35V76. Yesterday when it flashed on and then off. It blew the circuit breaker. I reset the circuit breaker and now the tv will not come on like it has no power at all.
  • denspot Dec 30, 2007
    We have exactly the same problem. It's been going on for a month or two. It does eventually stabilize and stay on, but it seems to be taking longer and longer for that to happen.
    Any idea how long we have until it dies completely?
    Genius:
  • 1,694 Answers
Key2life316,
Your TV has a bad picture tube = no reasonable repair possible......time to go shopping!....................T.
Guest,
Your TV has a bad pix tube + a blown power supply!!
Time to move on ........T.
Posted on Nov 28, 2007
Sony KP-53HS10 AND "5" FLASHES at Timer/Stand by Indicator
i had the same problem someone told me to take the front cover off were the speakers are there the middle were you change the channels take them screws out and becareful there is electric stored up in there dont touch anything there is a square box with3 screws on top and three screws on bottom
turn your tv to video 1 and the first screw on top closes to middle turn it to your right a little at a time you will see bright colored lines then turn it to the left until they go a way then do the same with the other 2 on the top then shut off tv for 5 mins turn back on ahit the focus button it workd for me but be careful
Mar 03, 2009 | Sony KP-53HS10 TV
TV turns off then on again
Have you replaced its Lamp?
If not yet, its time to replace it.
Sep 27, 2008 | Sony KDS-R50XBR1 50" HDTV
Codes for norcent tv for universal tv
Norcent lt2720 Power and screen problem turn unit on screen flashes and power still on 5-10 minutes later turn off then on picture comes on leave on picture go's off won't come on until procces repitted.
Jun 22, 2008 | Televison & Video
Green Flashes - Shuts off
Sounds like the green picture tube is defective. To confirm you can take the front grille and door off and tap the green tube lightly with something plastic, and not to touch any of the adjustment controls to confirm.
Apr 12, 2008 | Sony KP-57WS500 57" Rear Projection...
High Definition Projection TV
The flashes are a diagnostic. It should be only one flash pattern, either a 5 or a 10 (there are several other patterns in between as well). Please verify the number of flashes after power on, several times, and post back here, and I will be able to help with the fix. Based on your initial description, it my be the HV distribution.
Apr 02, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony Trinitron KV35V35
Could be a weak Picture tube . You can try turning up the screen control but don't turn it up too much you'll get retrace lines in the picture . Turn it alittle at time until picture comes on then turn it down until the retrace lines go away . Then try turning the tv on and off to make sure it comes back on. Be careful you can get shocked if you do this while it is on and you touch one of the circuits . The control is on the flyback or the module thats on the picture tube it will say screen by it . If this does not work you could have vidoe problems or just the picture is no good . Good luck
Jan 20, 2008 | Sony KV-35V35 TV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Sony KV-35S42 35" TV Logo
190 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
