Question about Akai LCT3201AD 32 in. LCD Television
42" AKAI plasma screen problems
Sometimes when I turn on the tv it has a funky coloring to it like its almost what an image would look like picking up on body heat or maybe even looking like a negative in a picture. Any suggestions to whats going on.
  • Feiro Jan 07, 2008
    1) LCD screen began shortly after first few days of use, showing bright green grainy areas. These seem to replace the certain colors. The problem seem to come and go but progressively has gotten worse. Now we cannot even make out most of the picture.
    2) We have tried different cable channels and it does the same thing on all channels.
    3) We have tried replacing the source cables from wall to VCR, from VCR to TV; we tried directly from wall to TV. No other TV’s in house have this problem.
    4) We have tried with DVD player, the same problem occurs from that source. We have checked the component cables to make sure correctly connected, blue to blue, green to green and red to red.
    5) We have tried from the VCR with commercial videos, not recorded videos. The same problem occurs.
    We have tried ALL of the suggestions in the troubleshooting guide with TV user’s manual. All is correct, nothing has changed since originally installed and all worked fine when we first began using it. Problem began a week or two after initial installation and daily use began. We have even tried resetting the factory defaults to see if that would help and the problem continues
  • Inita_TV_Fix Feb 06, 2008
    The picture from both cable and satellite source looks as though it is a type of “heat sensor” image. These fluorescent like effects are usually seen on the edges of items or on the brightest areas of a screen image. This is NOT a problem when viewing DVDs; they show perfectly. Initially when the TV was new, I was told that this problem was due to the fact that I did not have a digital input source so I just ignored the problem. Now that I have just recently upgraded to Direct TV (100% digital), the problem is still evident. Now, my TV is out of warranty and this has been a problem since I removed this TV from the box. I have tried every adjustment and connection configuration possible and I am still haveing the same problem. Can anyone at least tell me what is wrong or if this is something that is commonly due to a known problem of some sort? Any advice would be appreciated aside from taking it out back and shooting itJ !
    Genius:
  • 1,139 Answers
This is a sign of a lack of the luminance signal which may denote a problem with the chromanance signal ariving fast to the screen then the Luminance signal this is video problem. You will need to have a qualified TV technician look at this. You can find one on FixYa.com, or look in your area for one.
Posted on Sep 09, 2007
SOURCE:
I have a 46 inch Toshiba plasma tv. It is having a problem where the picture does not come up as soon as I turn on the TV. After about 20 minutes of warming up, the picture appears as normal but during the...
This tv is not repairable only can be replaced the Plasma screen itself.Not woth it,replacing the plasma screen,will cost the same as a new tv.This problems,u discribing is the Plasma screen itself sure comming to used and ages.Not any electronic boards componnent.Because the floorscents Plasma gas u seeing on the screen itself forming and lighting up the Plasma screen itself.
Dec 31, 2010 | Toshiba 42HPX95 42 in. Plasma Television
My tv has sound but no picture its an akai model pdp4206em1
Try unplugging it for an hour or so or try change sources , if the computer ever fell asleep while it was plugged in it is possible it triggered a sleep mode in the tv. Most will do such a thing. It is doubtful that the computer caused any damage to it but i would advise against using a plasma tv as a computer monitor because burn in WILL eventually occur with a static image left on the screen constantly.
Dec 26, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Mar 23, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Akai 42 inch plasma
Try putting a fan on the back of the tv to see if it is getting better. If it does then you probally have a board that is overheating. If that is the case then CAREFULLY !!! remove the back and place where you can turn on and safely access the open back NO TOUCHING STUFF !!! Mabey lay it face down on a glass table or lay it on a table with 25% hanging over the edge to see the screen. Then take a COLD blow dryer and blow it on the boards to find out which one makes it get better. If one does then it will probally be your problem board. Make extremely sure that is the one before removing it by blowing from all angles on the boards around it without air hitting the suposed problem board. Then try a little hot air to see if that starts the problem on that board so you can be sure. Of course check the surrounding and offending board several times to be sure before removing.
Apr 16, 2008 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Color problems
I have the same problem... today I got a digital satelite tech come out and hooked a HD digital reciever to the tv and now I have the greenish/yellowish/blue tint hhhmmmmmmm?
Mar 19, 2008 | Akai PDP4295ED 42 in. EDTV-Ready Plasma...
Monitor display had problem .
Hello Lunhoo,
Your TV should still be in warranty. If so, yes you should take it in for repair. Even if it's not in Warranty, Akai may have a special warranty extension for your TV. Check it out.
Good luck.
Feb 28, 2008 | Akai PDP-4216M 42 in. Plasma Television
Black Vertical Bar
It will burn into the screen overtime. The Akai units have a resistor on the address board that feeds the PDP that usually has a crack in the solder on one or both ends of it. There are about 4 address boards that are right below the panel itself and the suspect one is the board right below the line that is appearing. Have someone with solder skills repair it.
Jun 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai LCT3201AD 32 in. LCD Television Logo
175 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
KISHORE DESHPANDE
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
