Question about GE 46GW945 46" Rear Projection Television
Won't power up with remote or buttons on front. I have checked the fuse that is right by the power cord going though back of television.
  • nelle_9 Dec 11, 2007
    TV was humming, I unplugged it now it wont turn on with remote or buttons on the front.
WHERE WILL THE FUSE BE LOCATED AT
Posted on Mar 17, 2008
SOURCE:
Sceptre tv won't turn on after power outage
You may have to open it to see if the line fuse that the power cord goes to is good or bad.
Dec 23, 2012 | Sceptre Televison & Video
Hitachi lcd led tv won't turn on.
Without more info or seeing the set, the most likely problems are :- the inverter that powers the backlight has failed or the backlight itself has failed The first is the cheapest and easiest to repair the latter could mean the screen needs to be replaced. You don't say if you are getting sound though. if you aren't it may just be that the internal fuse has blown. I hope this points you in the right direction.
May 29, 2012 | Televison & Video
Why won't my TV turn back on even manually??
total dead usually means the fuse---unplug the set for safety and remove back cover---follow power cord just inside and you will find the fuse in a snap in holder--check to see if bad.............if good let me know and I will try to assist you.
Apr 03, 2012 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I have a 46" Flat Screen TV. Model Number
First thing you do is to check the outlet if there is a power output the check the power cord and plug.If there 's a power in the power cord,Check the fuse of your television.The fuse is located at the power supply.You can see the power supply when you open the back cover of your television at the upper right side.Replace the fuse if busted with the same value of fuse.That's the step you can do first..Thanks..
Aug 25, 2011 | Televison & Video
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No power to tv - but ac cord and wall outlet are fine though
hello the glass fuse inside the tv might blew make sure the tv unpluged take the back in the power supply you should see a glass fuse if the fuse is black then it's blew if you put another 1 in and it blows again then you have a dead short somewhere
shaun
Nov 06, 2009 | Philips 60PW9363 60" Rear Projection...
TV won't turn on
If you're any good at repairs I would check for an in line fuse. Check right where the power cord hooks into the TV. They sometimes blow just as you've discribed. If it's blown it's a pretty safe bet that replacing it will fix the problem. There is however a slight chance that something else might have blown it so if you replace it and it blows again take it to the shop. You've got a high 90"s % chance it's a 50cent fuse though. Good luck.
Feb 18, 2009 | Panasonic CT-30WX54 30" TV
Cant get the tv to power up
I'm having the same problem. No power at all, tv was working fine and shut off by itself WS-65517. Please help!
Oct 15, 2006 | Mitsubishi VS-55601 55" Rear Projection...
Televison & Video Logo
57 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
