Question about Logitech Z-560 Computer Speakers
Z-560 Can the Z-560 be connected to a stereo system
  • kram123456 Nov 15, 2008
    I am unclear of how to connect it to receiver
    Problem Solver:
  • 5 Answers
Yes they can, and would probably sound good. keep in mind the power rating of the speakers,as the output of a stereo/hts amp may excede this if the volume is to high. D-Dan
Posted on Aug 25, 2007
SOURCE:
Will Harman Kardon HK 206 speakers work with Dell Inspiration 560 with Windows 7 and if so how do you hook them up and install
since they are stereo they should have not issue. just connect the 3.5mm jack to your output port typically the green audio jack.
Jun 27, 2011 | Harman Kardon HK206 Computer Speakers
Does an audiobahn A2801Q throw 1000 watts
Hello... I can help you with this question. This particular amplifiers specifications are as follows:
  • 200 watts x 2 @ 4 ohms stereo
  • 280 watts x 2 @ 2 ohms stereo
  • 560 watts x 1 @ 4 ohms mono
    These specifications are RMS power, which would mean continuous "real" power output. Hope this helps!
    20 year car audio/video installer
    Bay manager
  • Mar 15, 2011 | AudioBahn A2801Q Car Audio Amplifier
    I connected my Sony stereo system to the philips
    Make sure you turn the tv audio outputs on, use the menu on the tv to do this. Make sure you connect the audio out of the tv to the audio in on the stereo system.
    May 01, 2010 | Televison & Video
    I drive a 1991 mercedes 560 sel and i want to change the stereo in it. The only problem is the wires that i need to connect to the new deck are not colour coded the same way the instructions are for the...
    see if the store that sold you the radio has a wire adaptor kit. they are available for most american/japanese cars so i would think a mercedes one should be available.makes easy work out of the job
    Apr 21, 2010 | 1991 Mercedes-Benz 560
    I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
    start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
    Oct 23, 2009 | Audio Players & Recorders
    Installed new 1080 plasma tv can't get sound from home theater system
    A home theater system usually consists of a dolby digital stereo amplifier and 5 to 7 speakers.
    Turn your stereo on and select the source that delivers video to the TV (DVD, VHS, Game, etc.). The video may be connected directly from the device to the TV, but the audio should connect to the stereo system (DVD, VHS, or other input). This way, the source audio is sent to the stereo and it provides the big sound to match the picture. Otherwise, you'd have to connect the source audio to the TV and let it's comparably tiny amplifier and speakers provide sound - that comes up short.
    When playing a DVD, select the DVD input on the TV *and* the DVD input on the stereo. If you do not connect the audio to the DVD input on the stereo system, you'll have to connect to the TV, otherwise nothing will be heard.
    Sep 17, 2009 | Audio Players & Recorders
    Pc compatibility
    The brother 560 has NO provision for connection to a PC.. The specifications do not mention PC compatibility, nor is there provision for either USB or RJ-45 connections on the machine.. You could use the phone line connector on your PC, but there is no exchange of data on the phone line between the PC and the fax. The phone plug on your PC is meant mainly for connection to the Internet via telephone, or to use the PC-to Fax feature, if so equipped.
    Apr 09, 2008 | Brother IntelliFAX 560 Plain Paper Fax
    Amp a2801q
    Audiobahn A2801Q
    Product Description:
    Class A/B MOSFET Circuitry
    Volt Meter With Blue Illumination
    PWM MOSFET Power Supply
    Double Sided Glass Epoxy Circuit Board
    THD: 0.02%
    S/N Ratio: >100dB
    Frequency Response: 10Hz - 40KHz (+/- 1dB)
    Variable 18dB Hi-pass Crossover: 90Hz - 750Hz
    Variable 18dB Low-pass Crossover: 30Hz To 120Hz
    Bass boost @ 45Hz: 0/18dB
    Subsonic Filter: 20Hz to 50Hz
    RCA Throughput Connections
    3-way Protection Circuitry: Thermal, Short Circuit and Overload
    Cooling Fan
    Cobalt Blue Illumination
    High gloss Chrome Plated Finish
    Nickel Plated Block Terminals
    Dimensions: 2"(H) x 12.75"(W) x 15.5(D)
    1-year warranty
    Jan 02, 2008 | AudioBahn A2801Q Car Audio Amplifier
    Loss of sound to Logitech Z560
    I repaired Z-560 speakers with a defective left front channel by chopping off one of the input leads close to the 3.5 mm stereo jack that goes into the PC and joining on the leads from a new one. At first I thought the fault lay in the main amplifiers in the sub woofer unit but I was wrong and it turned out to be far simpler to fix than I anticipated.
    Rod in Ottawa
    Aug 27, 2007 | Logitech Z-560 Computer Speakers
    Logitech Z-560 Computer Speakers Logo
    175 people viewed this question
    Top Logitech Audio Players & Recorders Experts
    Ekse
    Michial Gueffroy
    Paul
    Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
