Question about Cuisinart DCC-2000
WATER LEAK FILL WATER RESERVOIR AT NIGHT AND WATER IS ALL OVER COUNTER THE NEXT MORNING.
  • Anonymous Nov 04, 2008
    When I fill my Cuisinart 2000, water seems to leak out of the bottom
    next to where cup would sit. It is only when filled. It does not leak
    coffee--only clear water before brewing. I only fill for 8 cups.
    It is ruining my pull out shelf. I like the coffee maker but the
    leak is unacceptable. My husband wants to buy a different
    coffee maker
  • Anonymous May 11, 2010
    There is a "lip" at the back of the DCC-2000 which looks like a spillover control. If more than 12 cups of water is added, water will be spilled from this aperture.
    Does this spill mean all the water from the appliance is drained?
    Problem Solver:
  • 14 Answers
I have the same problem with my unit and Cuisinart Warranty is replacing my unit. Please see my post on this issue and perhaps calling them will net you a new machine or a fix to your problem. You will need the Serial number to your unit.
No guarantees by me of this, my machine is under warranty and I have no real information regarding yours.
Cuisinart Warranty 1-800-726-0190
Posted on Jan 14, 2008
SOURCE:
Why the water keep going down in the radiator when i fill it up?
It could be leaking into the cylinders. Check your oil to see if it looks milky
Jun 06, 2018 | Dodge Cars & Trucks
Water leak
YOU NEED TO PUT A COOLING SYSTEM PRESSURE TESTER ON .THIS WILL ALLOW YOU TO FIND THE PROBLEM .YOU GET LOAN ONE AT ADVANCE AUTO PARTS .look from every angle and you will find your leak.GOOD LUCK!
Apr 13, 2012 | Cars & Trucks
I have 85 toyota have changed water pump reader cap thermostat and still gets hot boils out water but when you put cold water it's ok for the rest of day sets over night start next day gets hot ag
did you let excess air out of radiator? after filling let it run for a few minutes with out radiator cap and make sure the water does not go down and serculates after thermostat opens, refill if needed
do you notice moister under vehicle in the morning ? possibly a gasket could be leaking.
Mar 30, 2012 | Cars & Trucks
Clear water leaks on the counter between morning and the next morning.
it must be overflowing.Its not leake.
check that if you totally turn the machine off for 2 days .The water still leaks.
If yes then replace the water inlet solenoid.
if not then check float sensor that its working properly.
Thanks
Please rate my work
Sep 17, 2011 | Bunn B10 Coffee Maker
Leaking
i got a vienna digital when i take the water container of to clean it 1 time out of 2 im gonna have water all over the floor what i do now clean the container put it back fill the water container with big glass and no more leak it probably have to do warp water container when it empty it seat perfectly when you have it in our hand it warp a little bit were not the only one with that me when i dont remove the container to fill it up i have no problem since then thanks for using fixya pierre
Feb 25, 2008 | Solis Master 5000 Espresso Machine
Coffee Makers & Espresso Machines Logo
170 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
