Question about Nike Triax Speed WR0085 wristwatch
Nike triax speed WR0082 regular
My strap broke on this watch. It's almost new. Bought it from a reputable seller on eBay. Glue didn't work; it wasn't super glue but some kind of craft glue that was described "super strong."
  • Morwen Mar 30, 2008
    My strap broke on an almost new Triax watch. The official repair couldn't fix it, so they got me a new one, which also broke shortly after but in a different way. I can't belive that it's so hard to make a decent plastic strap or fix some kind of cheap replacement.
  • babysinsky May 05, 2008
    almost new Nike WR0082-001 has been replaced due to strap breaking where it joins the watch. Now it just broke again. I worry I'll loose it one of these times. I'm hoping it will still be covered under warranty.
You must Re-Link the SDM pod to the watch after changing the battery. Go to the link below, It's not the exact model, but, should work, if not, go to www.nike.com and download the manual for your model.
GOOD LUCK
http://www.nike.com/timing/extranet/product/triax_elite/elite_manual_eng.pdf
Posted on Feb 17, 2008
Flashing time display
Nike Triax Fury 100 Super
You need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Sep 08, 2012 | Nike Wr0139001 Triax Fury 100 Regular...
I need a replacement strap for my Nike triax 35 watch but all the watch repairers I;ve been to say I need to order one direct from Nike. Can you help? Thanks
Log in to Nike website and click support button. You should be able to ask them how to obtain the part you are after.
May 18, 2011 | Nike Triax 35 Wrist Watch
Nike triax watch strap needed wg48 4000 grey strap
I'm having the same problem with the same model. Were you able to find a replacement strap? Thank you.
Feb 13, 2010 | Nike Oregon Series WA0019-001 Wrist Watch
I have a Nike Triax watch and the strap broke. The strap is held on with pins. How do I get a replacement?
Use this link:
http://www.nike.com/timing/?sitesrc=USLP
Select your region, then select support and get the answers. You may try retail locator as well.
Rate me, please.
Jul 29, 2009 | Nike Watches
How do i change the time on this watch?
Try to find it here:
Rate, please.
Mar 29, 2009 | Nike Midsize Triax 50 Regular Watch #R0082...
Strap Replacement
Maybe you can use it on an armband like with an iPod. Even with velcro.
Jul 24, 2008 | Nike Triax C5 Wrist Watch
Nike Triax Speed 100
Hi Symjoc. I can't find a way to comment there, so I will reply here.
Did you try asking the dealer on Ebay if there's warranty, if not, you can always try to sell it back.
Jan 02, 2008 | Nike Triax Speed WR0085 wristwatch
Triax CV10
Nike Triax CV10 - Successful HRM reset 7 November 2008
I had real problems too. Even after repeatedly following the known reset steps everyone else is posting up. Here’s how I got mine going, please forgive the mind bogglingly tedious detail…
First make sure you’re using new good quality batteries. I used Maxell’s, bought in 10’s from Hong Kong on ebay – no problem.
Second, and this is the ESSENTIAL bit…move right away from the computer and any other electromagnetic sources before carrying out the known reset…
Third, follow the known reset steps below, adjusted to what worked for me…
If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit.
Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button.
The re-initialisation steps for the Nike C10 and CV10 digital HRM's is:
(1) reset the watch
(2) open the battery door on the chest strap
(3) move the watch to RUN mode
(4) press the reset button in the chest strap battery area without removing the battery
Tip - I agree with the suggestion to use a pin or needle and definitely do it with the battery in the hrm.
Tip – Thumb holds battery to stop it from pinging out, other hand performs jiggle with pin until the link is made (it links straightaway if you jiggle it just right!)
(5) replace chest strap battery cover…and smile!
Nov 30, 2006 | Nike Triax CV10 Wrist Watch
Can Link watch with Heart Monitor
If you can't link the hrm do as detailed in the following link If you press all four buttons of your Nike HRM it will reset. Next time you go to "RUN" mode, it will show "HRM LINK" error. You will now need to "hard reset" the unit. Nike made a late change to add a "hard reset" to the chest strap. To re-link (re-initialise) the watch you'll need to open the battery door on the chest strap, and use a paper clip (or the equivalent) to push the small gold button in the battery area. There should be a small sticker in the battery compartment that points to the reset button. The re-initialisation steps for the Nike C10 and CV10 digital HRM's is: (1) reset the watch (2) open the battery door on the chest strap (3) move the watch to RUN mode (4) press the reset button in the chest strap battery area (5) put the battery back in the chest strap (if it's not already in - it's possible to push the button without removing the battery) (6) hold both of the electrode to create a signal (probably not necessary - it usually links immediately). My suggestion is to use a very thin needle and do it with the battery in the hrm. Eventually, Nike will either eliminate the hard reset or update the manual to include this info.
Sep 16, 2006 | Nike Triax CV10 Wrist Watch
Nike Triax Speed WR0085 wristwatch Logo
684 people viewed this question
Top Nike Watches Experts
Ansel Alberto
Ansel Alberto
TIME TRACK SERVICES
TIME TRACK SERVICES
Are you a Nike Watch Expert? Answer questions, earn points and help others
